Cross drilled/slotted Brake rotors
JVRacer04
Houston TX
selling a pair of cross drilled and slotted brake rotors for a 91+ Jeep cherokee
they did NOT fit my '89 and have never been used
may fit other models (TJs, ZJs?)
$60.00+ shipping (they are heavy)
local pick up = $65.00 or trade
Houston, TX 77040
If you need drilled/slotted rotors for early XJ/MJ, check out www.raceshopper.com. You'll pony up about a ton-fifty for a pair, but they're done with all holes radiused to eliminate sharp edges and heat risers, and are probably better than most on the market - AND they're the only outfit that does drilled/slotted rotors for early XJ/MJ that I've found so far...
5-90
sorry the pics are so small
there is a high interest in these rotors, ive checked 3 zips for shipping... all come out to be just under $25
there is going to be a flat rate of shipping = $25.00
Eddie G. was the first to PM me so he will get the first pick, if he passes then i will go to the next who PMd me or left a msg here
To your door total: $85.00
