- Westminster, SoCal
I need a light to be bright and then brighter. I have 2 12V lines to drive it. Problem is that the light is unfortunately one filament. So, I thought about it and came up with the following:
D would be a Rated 6 amps. 50PIV (For replacement and power supplies )
R would be a 50 ohm 10W 5% Wirewound Resistor
L is the light which is rated at 14V .33 A
I figure that the 50 ohm resistor would drop the brightness by a hair over 50%. The diodes would prevent backeeding.
Here's the diagram
Would this work? Or did I overlook something?
Here's the diagram
