LouisianaZJ
NAXJA Member #1362
- Louisiana
87 XJ Wagoneer D44 I would say "good" condtion
Specs:
Stock XJ width
XJ shock mounts
big drum brakes
5x4.5
i was told it is a track lock carrier (does not lock up, might need new clutches)
no sway bar mounts
new 75w-140 Royal purple lube
3.55 ratio
brake shoes appear to be 50-70% or so
no rust
e-brake cables included
I am currently running this under my rig and it runs pretty good, just looking to get something beefier instead of bulding this up.
I planned on keeping the shafts for spare, but it do have them for the axle and they are in good condition
perfer local pickup but will ship (probably $100-$150 to ship if you can take delivery at a shipping terminal)
I see junkyard housings go for about $300, and seeing as this has decent brake hardware and rust free.... i think
$350 w/o shafts
when I had the cover off all the ring gear teeth looked good, no chips or anything like that
Specs:
Stock XJ width
XJ shock mounts
big drum brakes
5x4.5
no sway bar mounts
3.55 ratio
no rust
$350 w/o shafts
