Old September 10th, 2004, 18:04
90Pioneer 90Pioneer is offline
Clunk/jerking when braking/accelerating on my new Jeep
Well I just bought a 1996 Country with only 63k miles. It's in great condition, and I'm 99% sure it's never been off road.
Whats happening is really hard to describe, sort of one of those "you have to be there" things, but I'll do my best.
When coming to a complete stop, like say at a traffic light, the Jeep sometimes will jerk slightly, right as you actually stop, and make sort of a clunking noise. It seems like it is coming from the rear end. It'll also do this when accelerating from a stop. I'll hear a clunking noise and feel a slight jerk, like some slack in the driveline is being taken up.
It happens about 50% of the time.
It's a 4.0 with an auto tranny.
I just had the brakes inspected and this problem is not related to them. Any idea what could be causing this?
Old September 10th, 2004, 22:15
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: Clunk/jerking when braking/accelerating on my new Jeep
Slop in the driveline that's taken up by the soft rear springs when you stop. Sometimes you can cut this down by greasing the slipjoint, but otherwise I don't know that it's ersolvable in stock configuration.
Old September 10th, 2004, 22:35
I dunno about that. I'm thinking it may be a U-joint or something. It also wobbles slightly in the rear end while moving at high speeds.
I am 99% sure what is happening is not normal, and definately shouldn't be happening.
Old September 11th, 2004, 18:17
Well I looked at all of the u joints and they appear to be fine. No play, but you can wiggle/turn both drive shafts from side to side, and up and down a little bit.
Took the rear pumpkin off, and everything looked OK in there too. Tranny mount appears to be OK.
What else could it be???
Old September 12th, 2004, 01:34
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Engine mounts?
Old September 12th, 2004, 04:45
JB98 JB98 is offline
Do a search on this and you'll find that it is very common. Yucca-Man is correct about the springs and the slip joint. Also, rear brake adjustment can help. I grease the axle yoke splines, leaf springs, and adjust the rear brakes and it will go away for 3k miles or so. But it always comes back. Use the "silver" grease (I think Loc-tite makes it) as it does'nt disolve as fast. Very common complaint.
Old September 12th, 2004, 06:07
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Drop the rear drive shaft,pull it off the TC out put shaft and coat the splines with Anti-sieze (silver grease ?) A small bottle is IIRC $6-7.00.Will be usefull on many items on your XJ.
HTH
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old September 12th, 2004, 09:41
Well it's good to hear that it's normal! Can any damage result if I don't grease it immediately?
Also would a 3.5" RE Super Flex with the full leaf packs fix this?
Thanks!!
Old September 12th, 2004, 10:02
themud themud is offline
Thanks!!
No it wont cause any problems because mines been clunking for years for the record I cant lube the slip splines on mine I dont have any and it still does it I figure its slop in the drivetrain and the chain in the tc...
The re spring pack wont help but ill help your flex offroad ..
themud
Old September 13th, 2004, 08:00
spaulman's Avatar
spaulman spaulman is offline
NAXJA Member #769
Check to make sure the spring u-bolts are tight.
Tale of an Old Jeep Rev Den Non-Tech / Off Topic 3 April 7th, 2005 02:22
dana 30 dana 44 and misc jeep parts cheroking For Sale: Private Party Only. XJ ITEMS ONLY 23 February 25th, 2004 15:15
FA: EBAY 1988 JEep Cherokee Intake manifold, Complete Tim88XJ For Sale: Private Party Only. XJ ITEMS ONLY 2 November 5th, 2003 12:05
Tales of an old Jeep jeep.xj.4x4 Non-Tech / Off Topic 0 October 16th, 2003 21:34
