Garthbmn7
NAXJA Member #524
- St. Paul, MN
Anyone know where I can find a chart showing the lengths of the OME shocks? What model i should be getting for my amount of lift type of thing?
Thanks
Thanks
OME makes more than just the above listed shocks for the xj now, that's why I was asking.
I just got Long-travel Sports for the front and was told by Dirk at DPG that they have the same travel specs as the old ones.
When I got them, I confirmed this by measuring. I would assume that they are all still the same.
How much lift are you running to go with the long travel sports? Did Dirk mention by chance when he recommends the long travel vs regular length ones? I'm shooting for 3 inches of lift on the nose, and trying to decide which shocks to go with.
Prosonic, did you do long travel on both ends for yours? Ome stuff was on backorder for 6-8 weeks, so I rounded up misc parts in stock across the country. Unbeknown to me, the guy at 4wd.com sent me long travels for the front and standards for the rear. After speaking with dirk, it sounds like this will be fine, I'll just get less droop in the rear. Do you have similar calculations for the rear of a 3" lifted xj?
