Old January 3rd, 2018, 07:52
97jeepxj1 97jeepxj1 is offline
Transmission pan bolt stripped
looks like someone cross threaded 3 bolts for my trans pan. Anyone know what size bolt is used in the pan? Was thinking maybe try a slightly longer bolt or if I am lucky use a long bolt and a nut on the other side but I can't remember now if that is possible on the aw4. It is in a 97 xj.
Old January 3rd, 2018, 07:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Transmission pan bolt stripped
Buy a Heli-Coil thread repair kit and fix it right.
Blanket caught in the rear liftgate latch. Now I can't open.
Old January 3rd, 2018, 07:59
lawagoneer lawagoneer is offline
Yes, what he said, easy to do and should take about 20 minutes to do all 3.
Old January 3rd, 2018, 08:03
That was my first thought but one of the 3 bolts is on the front (other 2 on rear) and I am not sure how well I can get in there with a drill and tap with the exhaust in the way. That and I need to know the bolt size for the appropriate kit.
Old January 3rd, 2018, 08:15
old_man's Avatar
old_man old_man is offline
With a helicoil the bolt will be the original bolt. You can score a kit for probably less than $20 local, and even less if you go Amazon or ebay. All you do is drill the original hole with the larger bit included in the kit. You then tap the hole using the included tap. Then you screw the insert into the hole using the included tool. Presto, you are done. Most kits contain several inserts. It only takes a few minutes, can be done from the outside without pulling the pan, and will be better than new and transparent to any future people working on the transmission.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old January 3rd, 2018, 11:09
m6x1.0x12. Slightly longer bolts worked well enough without needing to tap and helicoil it. Luckily those threads go further into the holes. Problem is after cleaning the pan up real good I realized that even with the borked bolts fixed it was still leaking. Turns out I'm leaking from the trans pan plug. Ordered another drain pain plug and washer at Oriellys supposed to be around 1. I seem to remember hearing somewhere that they plugs are made in such a way that supposedly they fail before the threads in the pan do so that you don't have to drill and tap them out.
Old January 4th, 2018, 06:00
cruiser54's Avatar
cruiser54 cruiser54 is offline
correct. The plug will strip before the pan. Always use a new gasket.
Old January 4th, 2018, 12:07
No leak now so seems to have fixed the problem.
Stripped Bolt Alienspecimen Non-Tech / Off Topic 9 October 12th, 2015 11:49
Stripped caliper bolt OnorOffroad OEM Tech Discussion 7 June 6th, 2012 22:03
Stripped Bolt... help mavrick OEM Tech Discussion 13 March 14th, 2009 22:33
stripped bolt... now what? Smittty9785 Modified Tech Discussion 1 February 26th, 2007 19:30
stripped transmission pan plug. Dano OEM Tech Discussion 1 February 3rd, 2006 22:57
