Old December 4th, 2017, 10:31
blakews2217 blakews2217 is offline
Well time rebuild the motor again
God itís a sickness when you get this much in a 4.0
Last build was awesome. Was a virgin block and head. Hereís the list of Work
258 crank with 242 rods
Block was punched .060 over
High flow oil pump
Head was worked by a local guy. I forgot all that was done but know it was ported/polished
Cam was a crane cams h-260-2.
Ran stock plugs at .040 gap
60mm TB
Stock engine management.
Was originally in a 1998 xj with 4 inches of lift and 33s. Ran the stock 3.73 gears and took it great
Jeep was wrecked. Hit in our driveway hard and totaled out. We bought it back just for the motor and tires.
Sat for a few years
Bought a 2k xj with a blown motor
Swapped it in and converted to COP
Ran great. Pulled good with the stock 3.55 gears and stock tires. I added the bigger 4 hole injectors. Ran better.
Pulled a full size truck up a hill in the snow ( was a 2500 ram 2wd. )
Hereís where things went south.
I was just cresting the top of the hill when it started to chug and miss. Limped to a buddyís house. Tired everything. Pulled the cam sensor and the cam gear was destroyed. Got a flat tow a mile home. Pulled valve cover and there was a few calapsed lifters and the cam gear was jumping teeth. Time to rebuild the second time.
Cleaned it all out.
I took the top end and my dad took the bottom end. I got a new cam ( same one) and lifters and cam bearings. Got it together
Dad decided to try to polish the main journals on the crank with some emery cloth. Bad move. Never put a micrometer on it ( we own a machine shop ) and never plasti-gauged it ( didnít believe in it) and got it all back together with fresh bearings, a stock oil pump, new rings and cleaned pistons.
Ran great but low oil pressure ( 5-10 psi hot)
That was in February.
Daily drive to school every day. Had a buddy living with me while we put a trans in his s10.
I let him borrow it when he needed it and only when he needed it. He gets back one day and itís clattering. The bottom end has now nicked up a small rattle. So I step up to 20w50 with 50% Lucas oil stabilizer just to thicken it up. Made it quiet for a while. I did a motor mount and spark plugs a few months later and picked up a miss. That was mere days ago. Itís now December.
Not bad for almost no oil pressure. But now I have another calapsed lifter from lack of oil to the top end. I still drive it when I need it because itís my daily but mostly I get rides where I need to go. So Iím going to document this tear down / rebuild.
The plan is to redo the build with maybe a bigger cam.
Or if I can do it for 1500 Iíll put an LS in it. Whatís the input here? Needs to be back on the road ASAP as my project truck is a 94 dakota with a 318 and a v6 driveline. Itís gonna be my DD
Old December 4th, 2017, 14:44
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Well time rebuild the motor again
The quickest and most dependable fix is to install another 4.0 block, stroked or not.
Installing a LS into your XJ means the XJ would become another project car.
Swapping engines is not usually done quickly or without hang ups.
Owned a 97 Dakota 4X4 short bed, with 318, for years. Once set up, it was a blast to drive.
I needed a lighter 4X4 to tow behind our RV, it was replaced by the 01 XJ.
The Dakota's weak spot was a front suspension that wore out quickly.
Both hubs were gone by 60,000 miles, the ball joints were never tight. CV joints were gone at 100,000. Don't lift it too much, the CV joints will not like it.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old December 4th, 2017, 14:51
Thatís kinda where I was looking. Luckily my dakota is a 2wd single cab long bed. I donít have a 4.0 layin around and I priced everything out about 1300 said and done so Iím gonna be looking at 1500 installed. I can do almost all the work myself.
Time to rebuild my motor? diggerdave OEM Tech Discussion 12 October 14th, 2013 11:30
AX5 Rebuild Time? acanfield OEM Tech Discussion 2 September 19th, 2005 21:16
Engine? Time to Rebuild KJR93XJ Modified Tech Discussion 6 March 4th, 2005 14:16
time to rebuild the 88?? xj paddler OEM Tech Discussion 14 November 26th, 2003 12:02
about time for a rebuild? squidwerd OEM Tech Discussion 2 July 11th, 2003 20:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
