Old December 2nd, 2017, 14:48
techno1154's Avatar
techno1154 techno1154 is offline
Ground for door lock
The door lock actuator have only 2 wires on it one for the unlock and the other for the lock function. Where is the ground? I assume it is grounded via the case. Is this correct?
I pulled the cover off the passenger front door today and pocked around in there a bit. The reason? The links on the door lock rattles quite a bit and are driving me crazy. It started a few days ago. The plastic keepers that hold the links to the lock seem to have worn out, old age I assume. I need to find a creative way to fix this,...I wonder if these keepers are available new?
The door look actuator have been an ongoing problem for some time now looking every time on the first try but seldom unlock electrically. The bracket on the actuator is riveted to the door. These rivets are loose allowing the actuator to wobble around. Replacing the rivets with bolts and nuts would stop the wobble but would it help electrically?
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old December 2nd, 2017, 15:47
Heavyopp Heavyopp is offline
Re: Ground for door lock
No separate ground -- the door lock actuator locks and unlocks by reversing the polarity thru the 2 wires
Drivers door lock switch- unlocks, but no lock? IslanderOffRoad OEM Tech Discussion 9 December 9th, 2014 03:49
passenger door set to lock but wont lock? jacksonbase OEM Tech Discussion 2 September 11th, 2013 09:10
WTB: door latch assembly, DS, 1997+ & door lock panel on door selarep Wanted: Private Party Only 1 May 3rd, 2007 22:22
power 4 dr. lock kit... on a 2 door... where to put the 4th door lock? selarep Modified Tech Discussion 2 April 22nd, 2007 20:52
Rear Brakes Lock Up on dry and wet ground???? jeepinairman OEM Tech Discussion 5 March 31st, 2005 13:10
