Old December 2nd, 2017, 15:45
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
Anyone brace their stock trackbar mount?
I've currently got a BDS track bar that I'm pretty happy with. The single shear bar works great on my Jeep which is primarily a DD, secondly a camping/wheeling/fishing rig. Currently sitting around 3.5" up front 4" in the rear.
My question is, has anyone built a track bar bracket brace for the stock mount? Something similar to the RE model or other brands that allows a brace to be bolted to the bracket and then the passenger side frame rail?
It would need to be removable and not interfere with the TRE style flex joint on the BDS track bar.
A new, double shear bar and bracket is not in the cards right now. I'm well aware that is the preferred set up.
Thoughts?
Old December 3rd, 2017, 08:39
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Anyone brace their stock trackbar mount?
Wondering why you think an RE type brace is necessary, especially for light duty use ? If you have the skills and tools to build a brace, why not just beef up the stock bracket, or build your own heavy duty bracket ?
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 3rd, 2017, 10:27
MG2000XJ's Avatar
Probably not necessary at all. Mainly thinking between that and a steering box brace, it would tighten up the front end, more rigidity I guess. Trackbars/brackets seem to be a likely spot for some play so why not. Preventative maintenance?
I couldn't build a heavy duty bracket for a tapered TRE style joint, I could probably pull off a brace.
Thanks!
Old December 3rd, 2017, 17:34
trippled trippled is offline
For what you do I would just drill the lower bolts out on the bracket to 5/8 and put new hardware in. If you're looking to stiffen the front some more look into something like boostwerks steering box brace. While I built my own brace, it felt much tighter taking corners at higher speeds.
Old December 3rd, 2017, 17:44
TRCM's Avatar
TRCM TRCM is offline
9/16 would likely be enough to remove the slop
Agree on the boostwerks brace....tightened mine up a good it.
Old December 4th, 2017, 07:20
burntkat burntkat is offline
NAXJA Member #1145
When you go to the larger bolt (9/16), there is no need to drill out the bushing. Just use a bushing for a 2001 Dodge Ram 1500. It's the same OD (In fact I suspect it comes out of the same mold, across manufacturers- Master Pro and Moog being an example I have recent experience with) and the same ID for the sleeve- the sleeve being a different ID.
Yes, you can certainly drill out the stock sleeve- but with most folks not having a drill press to do the job properly, why not just solve the problem for $20?
I came across this info when I bought the Clayton H/D bolt/nut kit.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 4th, 2017, 07:57
BenWheelin BenWheelin is offline
I'd say it's not, should take years of abuse at that lift height. Mine did. Over four inches in the front and they don't last long.
Old December 4th, 2017, 12:11
That's good info, but we were talking about the bolts for the bracket to the body, not the bushing.
Old December 4th, 2017, 16:49
Tim_MN's Avatar
The boostwerks brace is a fantastic product, but is even more overkill for a lightly/moderately 4wheeled truck than an RE brace. For a simple low cost solution, I would get a set of stock XJ tow hook brackets, or a pair of steering box reinforcements, and then weld some rectangular tube, behind the stock bumper, between the two brackets. Any decent quality off-road bumper that has proper frame rail mounts would also work about the same.
Old December 5th, 2017, 08:05
NAXJA Member #1145
How about a front receiver hitch?
Old December 5th, 2017, 11:17
Tim_MN's Avatar
This would also be a good low cost choice.
Old December 5th, 2017, 11:25
fetishfrog fetishfrog is offline
While I am still at and will remain at stock height, my front hitch definitely tightened up the front end. All my little rattles and such simply disappeared.
Plus you get a bonus extraction point that's rock solid.
Old December 5th, 2017, 13:39
NAXJA Member #1145
Yup, that is my intent. I just installed an IRO trackbar system and I swear I'm seeing a little bit of movement, even after putting a torque wrench on everything up front. Nothing is cracked, and I've put a C-Rok steering spacer up front as well. I think I'll expedite the frame reinforcement system and install a front receiver, and just be done with it all.
Best price for RE HD trackbar, mount and brace Mr. Pickle SoCal Chapter 7 December 11th, 2008 21:38
trackbar...redrill stock mount, drop bracket, or new adjustable bar? citRon Modified Tech Discussion 9 May 31st, 2008 17:54
RE trackbar brace & Kevin's Trackbar conversion ? xj-boonie Modified Tech Discussion 5 February 13th, 2008 23:52
WTB: Stock trackbar frame mount RedHeep SEC For Sale / Wanted Forum 0 February 9th, 2007 08:06
steering box brace trackbar mount XJ_ranger Modified Tech Discussion 2 June 4th, 2005 15:26
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
