Old November 27th, 2017, 17:31
ert01 ert01 is offline
What causes a long-start?
This is on my friends XJ:
'00 with reman 0630 head (still using the original distributor-less ignition)
New fuel pump
New injectors
New plugs
New wires
New waterpump/thermostat/hoses
New radiator
New O2 sensors (cat still intact)
Keying on/off a couple times prior to starting doesn't affect it. Still has a long start (indicating to me that its NOT a fuel pressure issue).
Hot/cold doesn't really change much. Always takes the same time to crank over... 5-10sec.
What else can cause a long start condition like this? I don't really want to get him to just start throwing money at sensors... but I'm not sure where to start.
Old November 27th, 2017, 17:55
RCP Phx RCP Phx is offline
Re: What causes a long-start?
Besides the fact that a 2k doesn't have spark plug wires....................
Until you put up some fuel pressure numbers????????????
Old November 27th, 2017, 18:45
Haha oops. My bad. Was just looking at my receipts trying to make sure I didn't miss anything important... but the wires were for my XJ (98). You're correct, his has no wires.
I can try to get some numbers but his Jeep is 50km away from me right now... sooo... what else should I look for next time I'm out there getting these pressure numbers?
Old November 27th, 2017, 22:30
Also forgot to mention:
new timing chain and gears
new oil pump
0331-0630 exhaust adapter plate
new head studs
His XJ had the long start issue before the head swap and again afterwards
Old November 28th, 2017, 07:00
90xj06's Avatar
90xj06 90xj06 is offline
when its cranking is the rpm gauge jumping up a little bit? might be that the ecu is having trouble seeing the engine actually turning.
any check engine lights?
Old November 29th, 2017, 18:31
JoeyJ55's Avatar
JoeyJ55 JoeyJ55 is offline
Try letting off the key after about 5 secs then try to start again after about a second. Any difference?
Sent from my iPad using Tapatalk
Long start Wiser OEM Tech Discussion 16 July 26th, 2016 15:41
Long start on a 98 ert01 OEM Tech Discussion 9 October 4th, 2011 16:50
long start dorkfish8765 OEM Tech Discussion 6 June 27th, 2008 14:45
Why's it take so long to start a 4.0? Zoro OEM Tech Discussion 35 April 7th, 2006 11:07
still long first start DARKFLY OEM Tech Discussion 7 October 8th, 2003 12:56
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
