Old November 22nd, 2017, 18:14
bradleyheathhays bradleyheathhays is offline
Parts ID-ing - axle side control arm bushings on a 96 XJ
I've ordered 4 new control arms only to find out they don't include the front bushings for the upper set, the one that has to be pressed out of the axle housing.
I'd like to go with Moog part MOOG-K3128 which is a two bushing kit..
http://www.moog-suspension-parts.com/moog-k3128
but the description is that each kit is to replace the bushings in the same arm, and that 2 kits are needed per vehicle.
So what I'm wondering is...are both bushings in the upper control arms the same? If so I could use just one of these kits to replace both the axle side bushings.
Old November 22nd, 2017, 18:47
lawsoncl lawsoncl is offline
Re: Parts ID-ing - axle side control arm bushings on a 96 XJ
Yes, all of the upper bushings are the same. This kit comes with two bushings. Good luck getting the old bushing out, and have a spacer handy when you press the pass side one back in so you don't bend the bracket. Penetrating oil, an air hammer or ball-joint press, and worst case a sawzall are the weapons of choice.
Old November 22nd, 2017, 20:33
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Sometimes quantites in catalog are wrong. The moog number you have dos have 2 bushings in it. So only one set req'd. Only 19$ at your local O'reilly auto parts.
As stated can be a PiTa to remove/install.
I endev up melting the bushings and hammering the sleeves out.
BJ press may work.
A tip for install.. Put bushings in freezer for a bit to help shrink them.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old November 24th, 2017, 10:56
md21722 md21722 is offline
The O'Reilly's Master Pro K3128 were the same as the MOOG's last time I looked. Both were Clevite. I'd save yourself the $10 and get the Master Pro as long as they are still Clevite.
Old November 24th, 2017, 18:45
Jeep Driver Jeep Driver is offline
The Master Pro suspension products are pretty good, better than moog.
Old November 26th, 2017, 14:53
comanche91's Avatar
comanche91 comanche91 is offline
I made up a bushing press from fittings and hardware in my junk box. Worked great pressing the new UCA axle bushings in.
Nevermind - the image isn't coming up.
upper control arm bushings axel side green95xj Modified Tech Discussion 21 March 15th, 2010 22:49
Axle bushings and control arm bushings bigjeepman OEM Tech Discussion 4 April 19th, 2008 09:24
control arm bushings axle side rngrfrd2000 Modified Tech Discussion 2 June 2nd, 2005 05:11
Upper Control Arm Bushings (axle side) SPSERG OEM Tech Discussion 4 July 30th, 2004 15:43
UCA Axle side Bushings.. Rob Bolin Wanted: Private Party Only 1 February 21st, 2004 01:45
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
