Old November 21st, 2017, 08:03
Aversnell Aversnell is offline
Can defective ignition switch kill instruments?
Changed several things in one day, including NSS and ignition switch, and now my instrument panel is dead. Cleaned and greased the two connectors in back, will go looking today for a bad ground, but also wonder if the new ignition switch I installed is the culprit since gauges worked fine before. Possible?
Old November 21st, 2017, 10:23
Re: Can defective ignition switch kill instruments?
Sorry... should have added 96 xj 4.0 2wd.
Old November 23rd, 2017, 11:05
80 views and no answer... seems a lot of us want to know but nobody knows. If I eve figure it out I’ll post here.
Old November 28th, 2017, 07:16
90xj06's Avatar
90xj06 90xj06 is offline
its possible something got bumped replacing the switch. check fuses and make sure nothing got shorted.
Need a kill switch. coldoath Modified Tech Discussion 12 November 30th, 2016 20:24
kill switch help azshtr OEM Tech Discussion 2 January 19th, 2008 08:03
Ignition kill-switch..how to Dvipercop Modified Tech Discussion 16 August 8th, 2005 16:36
Ignition won't kill the engine(?) Geepfreak OEM Tech Discussion 1 July 16th, 2004 14:53
Ignition kill on shift lever>? mark268 OEM Tech Discussion 6 December 3rd, 2003 04:20
