Old November 21st, 2017, 06:59
Aharris8510 Aharris8510 is offline
Will a 89 jeep Cherokee transmission and transfer case work in a 95 jeep Cherokee
I have an 89 Jeep Cherokee with a 4.0 straight 6 in it that has a blown motor I have a chance to get a 95 Jeep Cherokee with a 4.0 straight 6 that has a bad transmission I'm wondering if the transmission and transfer case from the 89 will fit into the 95 with no issues at all can someone give me some information or advice
Old November 21st, 2017, 09:29
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Re: Will a 89 jeep Cherokee transmission and transfer case work in a 95 jeep Cherokee
Should be able to as long as your swapping auto for auto, manny for manny. Engines won't swap without some hefty work. Your 89 is renix and the 95 is OBDI HO. Entirely different for a lot of components.
What tranny is in both?
Old November 21st, 2017, 10:08
I'm not sure what tranny is in both.
Old November 21st, 2017, 11:09
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Then you will not get a good answer until you have that info. This thread ( http://www.naxja.org/forum/showthread.php?t=1053970 ) will explain swapping an AW-4 Automatic.
Any 1990-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee 4.0L engine block will interchange and fit in any other XJ.
Remove and re-use as needed or required from your original engine: Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, distributor-less ignition or distributor assembly, engine sensors, motor mounts, fan belt driven accessories and/or mounting brackets.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old November 21st, 2017, 11:23
The 89 has the aw4 and the 95 has the 42re
Old November 21st, 2017, 15:24
smokeyyank's Avatar
The 42re is from a grand which would probably have the np242 t case. So are you swapping it to a grand vs a XJ? Can you swap it, yes, but depending on spline counts and cross members will dictate how easy.
Old November 22nd, 2017, 20:40
Tim_MN's Avatar
The 4.0 L engine blocks will interchange. Use the transmission that is the original type for the vehicle you are keeping.
1999 jeep cherokee, aw4 transmission problem. sjordanxj OEM Tech Discussion 1 June 22nd, 2012 15:19
1994 Jeep Cherokee 4 x 4pre runner - $65001994 Jeep Cherokee 4X4 .4.0L mtr 5 speed ma Tom_T&Js_Offroad SoCal For Sale 7 August 18th, 2010 16:37
1999 Jeep Cherokee Transmission Problem XJCruiser OEM Tech Discussion 5 April 30th, 2009 13:26
AW4 Jeep cherokee automatic transmission xjcherokee603 NAC Classifieds 1 April 8th, 2009 15:46
96 jeep cherokee tranny and transfer case 96jeepman NAC Classifieds 5 July 24th, 2008 19:52
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
