Old November 19th, 2017, 16:28
jk_surgeonfish jk_surgeonfish is offline
TC rear yoke output shaft seal leak
Again...why does it seem like a simple thing just does not end up that way.
The original SYE is from ProComp from around 2008. I called and got the part number for the rear output shaft seal that goes around the yoke. It is my understanding that the Procomps were make by Teraflex. The invoice from the shop that installed showed a part number of 4006. I only show 4007 in my research. Anyways I put in the following based on ProComps recommendation: Napa 18658 SKF.
Leaked like the titanic around the rubber seal that makes contact with the yoke.
So I called around and it was suggested I put in a National 473179. Put that in and it was better but still leaks around the rubber seal.
The National 473179 when you measure it against the original seal is the best fit.
Any recommendations on what seal I need to be using?
Thanks!
Old November 19th, 2017, 20:05
trippled trippled is offline
Re: TC rear yoke output shaft seal leak
Do you have the old seal still? There's usually a part number you can. Cross reference, it's just very small and hard to read. It's usually on the lip area somewhere. There's also no grooving in the yoke? Made sure to pack the spring and seal surface with grease?
Old November 19th, 2017, 22:02
I still have it but did not see a number the first time but will definitely look more closely.
Yoke is smooth and no grooving. I'm supposed to put grease on the spring and seal surface? I've only read about lubing with ATF and then installing.
Old November 19th, 2017, 22:15
That's my preference. I've had the springs fall off during install even with grease. T helps keep them in place and lubes the seal. And atf is fine I just prefer grease as an added precaution.
Old November 20th, 2017, 08:34
I did some reading and found Omix-ada 18676.62 looks just like the one I pulled. More research shows that it is an AMC-20 pinion seal and based on that I see NAPA 18444 is the part number they carry.
I tried the 18658 previously from Napa but that failed. Looking at 18444 vs 18658 the ID (internal diameter) for NOS 18444 is 1.844 where the NOS 18658 (leaked like the Titanic) is 1.875.
I'm hoping the smaller ID will create a better seal and not leak. Other forums have posted that the AMC20 pinion seal works on the SYEs they had from Rugged Ridge and Advanced Adapters.
I'll know later today when the part arrives.
Old November 20th, 2017, 13:58
md21722 md21722 is offline
In my repair notes, I have:
Replace TRANSFER CASE REAR OUTPUT SEAL - tried NAPA 18658 ($15.50) then used NAPA/CR 18662 ($19.36)
Maybe this will help. My SYE is a AA NP242. The 18662 has been in for about 45,000 miles with no seepage whatsoever.
Old November 20th, 2017, 16:13
Just tried the 18444 and the friggin thing leaks. I am trying 18676.62 next. If that does not work I am going to use some C4 on it. Really pissing me off now. On my 4th seal and they all leak.
Old November 20th, 2017, 16:51
RCP Phx RCP Phx is offline
Have you considered there might be anther problem?
Old November 20th, 2017, 16:53
Such as? The surface on the yoke is smooth with no grooves.
Old November 20th, 2017, 17:34
Maybe the covers not aligned? Are you sealing the spline threads? Maybe the rear output bearing is going bad? Are you sure where the leak is coming from?
Old November 20th, 2017, 17:46
I can see it leaking from around the rubber/yoke surface. It is not leaking via the splines to nut or around the seal to sye aluminum surface. Only where the rubber to yoke is.
I don't feel any play in the bearing. I thought about this as well.
Thanks.
Old November 21st, 2017, 18:25
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Not necessarily apples to apples, but the part number for the replacement seal for my JB Conversions SYE is National 472572.
I inquired and made a note of it for future maintenance purposes.
If you have dimensions (OD of seal and OD of yoke) it might be worth calling JB Conversions and seeing if they will sell you one of their own seals (provided dimensions are correct). Their seals are a double lipped design (springs on both the inside and the outside) which they have special made for their kits. It is not that the sizing they are using is out of the ordinary (thus the National 472572 potential replacement), but rather a matter of them wanting a superior seal. It sounds like you might be in the need for such a thing.
Output shaft seal or tail housing seal wishihad1 OEM Tech Discussion 3 July 3rd, 2014 14:20
transfer case rear output shaft seal nightmare rustbeltxj OEM Tech Discussion 3 July 8th, 2010 08:44
Quick- Rear output shaft Seal 49erRider OEM Tech Discussion 3 January 24th, 2009 14:46
Rear output tranny seal leak, snap ring broke! Red97XJ OEM Tech Discussion 10 July 21st, 2006 21:02
Output seal leak Zoro OEM Tech Discussion 8 October 21st, 2005 21:16
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
