Old November 15th, 2017, 16:42
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Two Questions
My Jeep needs a head. Anyone want to recommend a high performance head for it? Its the 4.0 engine.
I was also curious about changing that bearing for the pulley driven fan. You know the one that is built into the ac bracket? Is that changeable or do I have to find some place to buy the whole contraption new. I have a suspicion it squeaks
Thanks all!
Old November 15th, 2017, 20:34
blakews2217 blakews2217 is offline
Two Questions
Thanks all!
The best bolt on solution that Iíve personally used is actually another stock head. Weíre looking for the 7120 head. Early 1990s. I think 90-93? Iíll have to look it up again but itís widely available. That head has the best ability to be worked by someone and best of all.....itís stock so it can use the stock gaskets. The only thing you have to do is trim the manifold gaskets. Just remember if you have the head shaved it will probably throw off the valve train.
Old November 15th, 2017, 21:30
Heavyopp Heavyopp is offline
Re: Two Questions
There is a thread thats been brought back from the dead recently about the bearing replacement -- the last page has a link to a video showing how to do it
http://www.naxja.org/forum/showthread.php?t=43081
Old November 16th, 2017, 00:01
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: Two Questions
Head.. Russ P
Pulley.. I recall someone found a way to replace the bearing. Other option is replace the bracket
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old November 16th, 2017, 03:03
RCP Phx RCP Phx is offline
Re: Two Questions
For the head I would also recommend Russ(Bishop/Beuhl)! After that there's Edelbrock and Hesco. Here's Russ's work on my head.
Old November 16th, 2017, 08:19
alexgalexg's Avatar
Re: Two Questions
I wanted an Edelbrock head but the problem is they want like 2k for it. And I hear they dont stand by their products. I ended up shooting that Russ guy a message so Ill see how that goes. I found some 0630's online but they all had no reviews and were not new.. Reman only which is a route I would like to avoid if possible. As for the ac bracket I dont have all the puller tools for that method. I think ill just favorite the video and take a bracket off another jeep for now
Old November 16th, 2017, 08:55
Re: Two Questions
Russ has options from "mild to wild" so it helps if you have a "direction" that you want go beforehand. I went all the way with him so it wasn't cheap! What year is yours?
Old November 16th, 2017, 09:41
alexgalexg's Avatar
Re: Two Questions
Mine is a 1998. Im looking for the best performing head I can put on my 4.0 that will be plug and play. Nothing that would make installation any different from a stock head. If this happened in warmer weather I would be more open to things that might not be quite plug and play but I am stuck swapping a head outdoors in the snow, rain and wind so I dont want this to take any longer than it has to.
Another note is what is the deal with fel pro gaskets. Anyone have problems with their head gaskets? I have always heard they are a good brand but I want to be sure.
Old November 16th, 2017, 10:44
Re: Two Questions
All the heads regardless of what has been done are "plug-n-play". You should call Russ and see if he has one "ready to go". Mine took 6+ weeks to get done! As far as Fel-pro goes I've used 1000's and never had a problem!
Old November 16th, 2017, 19:00
macgyver_7_6 macgyver_7_6 is offline
Re: Two Questions
Which gasket....the head to block....or exhaust/intake?
I bought a felpro exhaust/intake gasket when I put on my header.
The gasket holes were much smaller than the holes on my head.
I ground the gasket holes to match my head.
I was quite surprised since I've never had a felpro product that was inferior such as this one.
Old November 18th, 2017, 07:35
alexgalexg's Avatar
Re: Two Questions
Head, valve cover and intake gaskets are all fel pro. Even head bolts are fel pro. I wanted to make sure people still stand by them in recent years before slapping another on. Although Im sure the dealer gaskets are worse now that Chrysler is running the show
Old November 18th, 2017, 08:34
ehall's Avatar
ehall ehall is offline
Re: Two Questions
I helped a guy install a CCH head, not a performance head but it was very solid
my '91 beater rebuild
Old November 18th, 2017, 19:17
alexgalexg's Avatar
Re: Two Questions
I searched my make and model with the 0630 cast number and clearwater said no search results
More RENIX spark questions (wire colors / volts questions) FilthyLlama OEM Tech Discussion 8 November 25th, 2013 19:03
Remanufactured motor questions couple of questions.... pikey77 OEM Tech Discussion 5 May 29th, 2008 07:14
Brake mod questions, different diaphrams and MC combo questions sycho15 Modified Tech Discussion 7 March 14th, 2006 10:23
A few fuel pump questions and 1 exhaust questions Cottontail OEM Tech Discussion 3 August 9th, 2005 19:16
Head Gasket replacement questions and upgrade while I have it apart questions Talyn OEM Tech Discussion 8 March 9th, 2005 11:53
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
