Old November 12th, 2017, 14:54
oldbill oldbill is offline
Where cn you purchase the various electrtical connectors
Other then possibly the dealership where can you purchase the various electrical connectors with or without pigtails that are used in a 2000 Jeep Cherokee.
Old November 12th, 2017, 15:37
tech1001 tech1001 is offline
Re: Where cn you purchase the various electrtical connectors
I've seen some at Rock auto .
Old November 13th, 2017, 00:34
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Napa and Rock Auto are my two sources.
Expect to sped some bucks, stock-type connectors are expensive.
Best place to find them cheap is at a pick-a-part type wrecking yard.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old November 13th, 2017, 18:24
Waynerd Waynerd is offline
Not sure which ones are available but I would assume all of the most common ones. I did find the connector to the blower resistor recently. Also I remember seeing one for the oil pressure sender before.
What do these connectors go to? Spearfisher XJ OEM Tech Discussion 6 June 30th, 2012 15:38
Connectors for what??? SuperRoo OEM Tech Discussion 17 August 25th, 2008 15:47
H4 Connectors... mikeny59 Modified Tech Discussion 5 December 26th, 2004 20:27
connectors RWB214 Wanted: Private Party Only 0 August 15th, 2004 20:15
Connectors ZombiE OEM Tech Discussion 3 June 2nd, 2004 20:39
