Old November 9th, 2017, 21:25
drewmj drewmj is offline
Cutting off welded rock sliders
Hey guys, this might be a dumb question but bear with me. Just bought an MJ and the PO had welded some large diameter tubing onto the frame rails. I'd like to replace it with some real full length rock sliders to protect the whole rockers as well as the front of the bed. What would be the best way to cut the old ones off? The tubes have been welded(poorly) to the frame rails front and rear on each side. Should I cut the tube a half inch from the frame and then grind/hammer the rest off? Or just carefully cut the welds right against the frame?
Old November 10th, 2017, 04:59
Mach2nh Mach2nh is offline
Re: Cutting off welded rock sliders
With the Uni being so thin i would cut close and grind the rest off with a 60 or lower flapper. Hard grinding disks take big bites if you are not careful.
Old November 10th, 2017, 07:18
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Sawzall the tubes off flush as possible and break out the angle grinder
Steps welded on to my rock sliders? XJNOOB93 Colorado Chapter 1 March 18th, 2017 16:07
A/T's in the rock gardens?-welded beadlocks pataterchip Modified Tech Discussion 14 November 20th, 2007 14:45
rock sliders vs tree sliders?? alwaysready Modified Tech Discussion 1 June 19th, 2007 13:18
rock sliders vs rock rails razorbackxj Modified Tech Discussion 30 November 6th, 2006 21:16
Rock sliders Brian Felts Modified Tech Discussion 1 September 27th, 2004 18:23
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
