Old November 16th, 2017, 15:47
Slimer Slimer is offline
Re: XJ tries to change lanes when letting off gas
Originally Posted by Rockwood View Post
Physics. Locked diffs make shit go straight. You naturally add steering to force it around a turn. When you remove the reason you needed more steering, you "change lanes".
I don't think that is the case, it pretty much takes the same amount of steering effort locked or unlocked. I don't know how to explain it, but it kind of veers hard for a second and then goes back to normal. I did drove it on the skid pad at Bondurant and if I let off the gas during a turn it darts and then returns to normal very quickly after.
Old November 18th, 2017, 22:02
TRCM's Avatar
TRCM TRCM is offline
Mine did some weird stuff when the shackles were bad...locker and no locker both
Old December 2nd, 2017, 15:33
I replaced the rear shackles today. They raised my rear end about two inches and helped to solve some of the handling issues.
Old December 2nd, 2017, 15:35
One side came out easy. On the other side the sleeve inside the upper shackle bolt had split and siezed to the bolt. I was able to unthread it from the blind nut and then cut it with a sawzall.
Old December 2nd, 2017, 18:17
TRCM's Avatar
Man, them things were shot as bad as mine were.....
Old December 3rd, 2017, 16:29
Suprmn Suprmn is offline
Mine had the exact same problem. While mine is not cured 100%, my main problem was the mounts at the front of the rear springs. The passenger side mount broke loose the captured nut and over time wore the mount to where the bolt could track about 1/4 inch backward and forward in the mount. I was not able to see that the bolt was moving as most of the travel was where the captured nut broke loose. From the outside all looked good. Put synergy front spring mounts on and it’s all good now. The remainder of my issues is from my cherokee living a pretty hard former life. Incidentally, synergy quit making the mounts but I believe hooligan makes them now.
Old December 4th, 2017, 17:39
My XJ now handles better, but it is really noisy now. The new bushings really make a lot of noise.
Also, I can't recommend the Rusty's Shackles enough. I do recommend buying some new hardware though before you start the project.
Rusty's XJ Shackles
Old December 4th, 2017, 20:25
TRCM's Avatar
You didn't need the boomerang shackles, but they do work too.
Noisy ?? I have the Rusty's straight shackles, and once I lubed them up, put the weight on them, then tightened them up, they make ZERO noise at all.
And yes, I got all new hardware from the local bolt store....much easier than fighting the 20+ yr old stuff.
After TDS, letting everything go at cost. RWKHausSupply SoCal For Sale 3 March 8th, 2012 11:56
odd noise when letting off gas dan302492 OEM Tech Discussion 10 August 22nd, 2008 17:13
not letting me change my email gunthagunth User Support, Questions and Suggestions 2 February 15th, 2006 17:38
Just letting off some steam theslacker Non-Tech / Off Topic 0 March 26th, 2005 22:16
Thank you for letting me serve Andy Steiner SoCal Chapter 4 March 3rd, 2005 12:33
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
