Old November 1st, 2017, 12:49
sinat01's Avatar
sinat01 sinat01 is offline
Rust repair/ body mods
Ill try to upload pics when I get home but here is what im dealing with.
1999 2 Door Cherokee
built rock rails in place of the rocker panels.
I want to do the cut n fold, buut instead of folding whats left of the rusty metal. I want to cut it off and make a plate to go in there. Has anyone done this instead? and if so, how heavy of a steel did you use?
the other issue I have is the door hinge pins are worn (again) the bottom hinge is ovaled out, and I have the typical cracks around the vent in the door frame. I want to get the braces that weld in, and figure since im doing one, I might as well do the one to brace the hinges also.
Could I drill the ovaled out hole back to round, and size up a bronze bushing to go in the whole and use a bolt or pin to keep the door where it needs to be?
Old November 1st, 2017, 13:04
sinat01's Avatar
Re: Rust repair/ body mods
Old November 2nd, 2017, 08:59
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Originally Posted by sinat01 View Post
You don't say.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old November 2nd, 2017, 12:01
sinat01's Avatar
I really hate that photobucket sucks, gotta figure out how to upload the pics
Old November 2nd, 2017, 19:40
Jeep Driver Jeep Driver is offline
https://comancheclub.com/forums/topi...-evolution-88/
First and second page I deal with my hinges.
Old November 4th, 2017, 12:29
sinat01's Avatar
Ill have to check the thread out at home, work computer wont show pics
Old November 5th, 2017, 10:41
jeepingben jeepingben is offline
I did something like that. http://www.naxja.org/forum/showthread.php?t=1073367
I didn't save any of the measurements, but it isn't square so you will want to make a template before you start bending steel.
I used 16 or 18ga, I can't remember which.
Lots more pics here:
https://www.jeepingben.net/zen/zenph...rockers&page=3
Old November 5th, 2017, 15:46
sinat01's Avatar
if this decides to work (the pic) this is the fun rust repair I gotta do
Old November 8th, 2017, 22:20
sic3335 sic3335 is offline
I had the same issue with my lower rear quarters. Rusted out too much to do the cut and fold so with the combination of an angle grinder and sawzall I cut everything off and then welded in a plate. I watched this video https://www.youtube.com/watch?v=55FCUBiCCZg and just cut along the same lines he finished with. Can't remember the exact thickness of the metal used, but it was thicker than what I cut off as the welder tended to blow right through the thinner stuff I had. I'll be doing more and fixing a small rusted spot in the floor tomorrow and can supply pictures if needed, just let me know.
Rust Repair/ body mods help sinat01 Paint and Bodywork forum 0 October 31st, 2017 13:43
another rust repair rastein77 Modified Tech Discussion 11 February 23rd, 2014 10:01
Body shop for rust repair in NoVA? N8N_99xj South East Chapter 1 March 28th, 2013 11:47
95-xj-rust repair 95xjpa OEM Tech Discussion 3 March 29th, 2005 07:18
rust repair nfldXJ OEM Tech Discussion 6 February 4th, 2005 14:21
