Old October 23rd, 2017, 18:30
BenWheelin BenWheelin is offline
Sawsall proved to be a poor candidate to extract a late model firewall
Is my Jeep modified enough to post here? I drilled all of the spot welds, modified the inner fenders, and welded the entire core support from a 92 into my 86. I have a clean engine bay, clean firewall on both sides, and pretty much nothing forward of the body wiring harness connectors. This was all pretty simple, actually.
When I went to practice on a junk tub, I found my plan of changing the center of the firewall to be more involved than I previously anticipated, namely, extracting the section with a reciprocating saw may not have been my brightest moment. So despite my abhorrence to unwarranted violence, I've decided to go the sledgehammer route in my quest for 4.0 clearance, while using hole saws for the shift cable and trans control wiring. I understand that this is a fairly unorthodox swap, but I was hoping some here may have pictures of the end result.
Also, now that you've had adequate time to shake your head, know that this is a well equipped two door, the transmission from which more than paid for this entire project, and my only out of pocket expenses are bits, blades, and paint. Thanks for posting.
Old October 23rd, 2017, 18:34
Jeep Driver Jeep Driver is offline
Re: Sawsall proved to be a poor candidate to extract a late model firewall
Pics?
Seems like no one on this site owns a camera.
Old October 23rd, 2017, 19:21
I actually have an excess of pictures which all proved fairly useless in the project so far, but I imagine they could be of some use to one considering a core support swap to convert a 2.8 (or 2.5) to accept the wide radiator and modern hood latches. I'll get them uploaded.
Old October 23rd, 2017, 19:44
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
I'm sure that was a ton of work, kudos for tackling such an ambitious project.
On a side note for anyone else considering swapping a 2.8 in favor of a 4.0....
An LS4 is the same bellhousing pattern as the 2.8.
You get an all aluminum 5.3 liter V8! Just have to fab some motor mounts, some headers, and a starter mount.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old October 23rd, 2017, 19:50
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Originally Posted by Jeep Driver View Post
Pics?
A lot of it has to do with people getting boned by photobucket and not taking the time or not being able to move their photos to another service. Photobuckets download service also seems to have a lot connection issues lately with lengthy repair times
Old October 23rd, 2017, 19:53
Apparently the pictures cease at the mock up phase just before welding. I have some potato pictures I could dig up of in between welding and engine out.
Here was the problem with the 86 when I bought it. V6 was running great when it came out.
Early and late lower core supports.
Corner braces extracted and ready.
Late model inner fender profile, left.
Late model inner fender profile, right.
Template made from late model inner fender and donut box from coffee shop.
Mock up with all braces in place. Note that the frame has been cut and laid over, I'd suggest that you weld in the lower support top and bottom before laying it down. All of the vertical studs in the area are removed. I also took the opportunity to create a bit more clearance for the lower transmission line, (going auto because cheap) and I made a notch for a hose on the petcock on the opposite side. No more draining coolant everywhere.
Old October 23rd, 2017, 19:57
I actually did a good bit more trimming after that last picture and before welding it all up. You can tell I folded that side first.
Old October 23rd, 2017, 20:11
I already have a 5.3 donor waiting for another project, a 57 Townsman wagon, but that's another forum. I don't even know why I'm doing it, I was in the middle of building a 90 until I came to the conclusion I'd have to pull the engine for freeze plugs. A compression test revealed I'd rather put freeze plugs in a low mileage donor engine out back, and then I decided that maybe I'd just put it in this one because I drove it for a while and I like two doors. I'm gutting a low mileage 92 to build both but the other one is staying Renix, and I like Chrysler fuel injection better. On that note, I'm getting rid of all the Chevy stuff from my Jeep short of the steering column and box, which will still be late model spec with a shared ignition and door key.
I also have a ZJ with a 5.2 I could have gutted, but this is the best of what I have to choose from. The 4.0 from the 92 still runs fine, but I flogged it hard across Arizona for a week and loosened it up a bit. It'll suffice until I have it organized and I'll drop the better engine in resealed later.
Old October 23rd, 2017, 20:39
NAXJA Member 4950
The 5.3 LS4 is a different animal than an LM7. They were redesigned for front wheel drive and have the active fuel management
Old October 23rd, 2017, 21:19
I'd say I understand, but the interest just isn't there. I have several Chevrolets in various states but I choose to build a Jeep at the moment. A 92 Laredo two door with a 4.0 is hard to find around here, and it's what I want. 75% is plug and play. The fun part is going to be splicing the body harness, or modifying the late model four door harness to fit the two door. I'd rather just replace the fuel tank circuit and leave the rest original in the rear.
I also have a 92 Laredo I paid $300 dollars for, built a nice rig out of, then discovered the lien.
Old October 23rd, 2017, 21:22
Then, there's the big engine, AX5 problem.
Old October 23rd, 2017, 21:33
JohnX's Avatar
Sarge <3 Ben
True, I was assuming auto trans...which could be built for the v8 power.
Johnx is #1
Old October 23rd, 2017, 22:40
Cut-off wheels, a plan, patience.
Not a BFH!
Oh boy...........
Chuck the clump, strip the bay, clean up your mess..........then cut.
Old October 24th, 2017, 05:32
jonb8's Avatar
jonb8 jonb8 is offline
I swapped the lower/center of the firewall only on a 85 2dr. Worked great but had to swap heater box also. What I didn't take into account until my starter went out was the top starter bolt won't come out....LOL Don't forget to check that...
Old October 24th, 2017, 08:29
It's things like this I like to know. I see no difference on that side, wouldn't expect it in a million years.
The HVAC cabinet is already out, and the AC worked great in the donor, so everything gets swapped. I'm waiting to break the system so as to have as little time open as possible, but I like the idea of cold air in an 86.
Do you run antique/classic tags? I have a pair of Texas sesquicentennial tags for mine. 1836-1986.
early model flares on late model N8N_99xj OEM Tech Discussion 2 February 16th, 2017 16:19
early model doors on a late model? Demonoid369 Modified Tech Discussion 19 April 1st, 2013 17:41
WTB late model XJ *whiteXJ* Red River Chapter For Sale/Wanted 6 January 26th, 2013 13:58
making late model 1/4 guards/light boxes work on early model in4aride Modified Tech Discussion 9 July 28th, 2010 08:07
