Old October 5th, 2017, 09:20
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
tj front D44 into xj, why isnt this more common
hey all. not having an easy time seeing many of these installs, maybe 3 threads off google. ive been looking for a week and it might as well be a tall tale swap.
is there any reason why the tj rubi front d44 isnt a more popular swap into the XJ?
is it rare, is everyone modding xj wagon axles or similar....?
ideally if i could get one out of the yard. it would become a 4.56,trussed, and new uca brackets for LA.
is this a difficult axle to source from the yard?
really looking for any helpful insight, im not sure why it isnt more popular/ more info on this.
likely ide add a different locker.... really i would just want to build the tj d44 or see its potential when built up.
thanks for bearing with me guys, im not above research, but i must be missing something to not find better info on this.
further more does this axle have any axle spline upgrade options? i know knuckles are the same as d30.
another ? that popped into mind is what would be the value of shortening a jk 44 and clocking the Cs to an xjs angles vs a tj 44 build.
current set up is a 8.25 rear locked, hp30, 4.56. im looking to gain knowledge on swapping a stronger hp30 substitute.
your thoughts, wisdom, knowledge is appreciated, thank you.
Old October 5th, 2017, 09:23
RCP Phx RCP Phx is offline
Re: tj front D44 into xj, why isnt this more common
Most likely the fact that they are a LP D44!
Old October 5th, 2017, 11:09
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Its low pinion and the jk axle will require the same if not a little more work than swapping in full width or wagoneer axles.
Old October 5th, 2017, 11:32
VAhasnoWAVES VAhasnoWAVES is offline
wagoneer 44s are LP... people do those all the time. but i would put it as a close second. first and foremost, TJ stuff fetches a premium. basically, if it came out of or goes into a wrangler, expect it to be expensive. its also essentially a LP44 center section with D30 outers. all you are getting is a bigger ring gear.
now... the JK stuff is a completely different animal. unfortunately it doesnt adapt easily to 5on4.5 bolt pattern. your better bet is to also use a Jk rear axle. youll appreciate the little bit of extra width. itll let you use a properly back spaced wheel for scrub radius and help keep the tires off the control arms.
Old October 5th, 2017, 16:22
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Primarily its that they are uncommon and go for more money than they are worth. If I stumbled over one for $800 or less I'd drop it in my jeep before dinner tonight, but the few that come up go for top dollar, and they are barely better than a HP 30.
Old October 5th, 2017, 16:27
haha that explains not seeing them ever,
thank you sir!
Old October 5th, 2017, 20:01
ehall's Avatar
ehall ehall is offline
They are kind of rare. Also not that good relative to other D44 options, the only [immediate] advantage over D30 is the larger ring and pinion and the built-in air locker.
I have TJ Rubi 44s in my XJ, but they were partly built when I bought them, and it saved me a lot of money over doing the initial work myself.
my '91 beater rebuild
Old October 9th, 2017, 14:03
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
Ditto
I'm running a trussed one up front. Bought it with the brackets cut off, swapped 4.56's and an arb with a matching 8.8 for the rear at a price I couldn't pass up.
But For the price most people and yards want for them in my opinion there are better ways to go.
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old October 11th, 2017, 07:30
themauler's Avatar
themauler themauler is offline
Originally Posted by IslanderOffRoad View Post
Ditto
The day I see a rubi TJ in a junk yard is the day hell freezes over!
Old October 11th, 2017, 09:59
NAXJA Forum Addict
Not self service yards that's for sure
But the dismantlers seem to get them on occasion and want $1500
John V.
Old October 11th, 2017, 17:21
ehall's Avatar
and they are 30-spline vs the 27-spline D30
but that also makes it harder to find spares
Old October 12th, 2017, 12:21
kcox506's Avatar
kcox506 kcox506 is offline
I managed to snag a Rubi 44 off someone who ordered a Dynatrac, only real way you can seem to get one these days. Rubi locker and all. No way you'll find one in a yard. Have a build thread on here covering most of the swap.
The low pinion factor isn't really a deal breaker for me. 4.10s are a thick cut gear and the axle can get stuffed up nicely at compression. If you're in the racing business I guess thats a thing. But like everything else, opinions may vary.
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
tell me why this isnt done Ewenm Modified Tech Discussion 15 May 27th, 2013 18:50
4wd isnt working stevelknieveleer OEM Tech Discussion 3 November 2nd, 2008 12:06
A/c isnt cycling and electric cooling isnt working brianb2247 OEM Tech Discussion 5 March 26th, 2006 23:52
PLEASE tell me this isnt true! summitlt OEM Tech Discussion 6 December 12th, 2005 00:11
Quiet In Here...Isnt it? 0313 Intermountain Chapter 35 November 19th, 2004 22:35
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
