Old September 30th, 2017, 17:21
cbwymore cbwymore is offline
No turn signals after removing dash.
2000 XJ 4.0L auto
I removed my dash to replace heater core and A/C evap core, got it all back together but when I took it for a test ride the turn signals don't work and the flasher relay stays on (buzzes). The hazards don't work and the indicator lights do not come on either. Headlight, markers and brake lights all work.
I replaced the flasher relay and it stays on. Any assistance on where to start looking or a diagram on the turn signal system would be greatly appreciated.
Old September 30th, 2017, 17:31
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: No turn signals after removing dash.
One might suppose that you did not fully seat a wire harness connector, re-check your work. Failure of the turn signal switch assembly is somewhat common, but logically if the signal worked before, and don't work now, either you forgot to plug in something, or possibly something like a wire or two got damaged.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old September 30th, 2017, 17:56
Thanks. I pull all the trim around the steering column and it works now. Some thing must have been binding.
no brake lights, turn signals or dash lights bmxdude151 OEM Tech Discussion 6 September 9th, 2013 08:51
bad ground?? ARB bumper turn signals out of phase with xj signals NeXJ OEM Tech Discussion 1 September 16th, 2010 17:05
Help! Electrical disaster, turn signals/hazards/dash.... ResurreXJion OEM Tech Discussion 6 March 17th, 2008 10:42
turn signals jfox21 OEM Tech Discussion 6 June 27th, 2006 23:03
Help with turn signals 85Chief OEM Tech Discussion 2 September 12th, 2004 20:36
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
