Old September 4th, 2017, 12:38
sic3335 sic3335 is offline
Slow Speed front end noise
I just finished installing a 4.5 inch lift on 33's on my 00' XJ Classic. Still needs an alignment but just putting around the neighborhood to see how it drove, there was some noise coming from the front end from 1mph to about 10mph then it stops and rides fine. I've checked and tightened EVERYTHING three times and greased up the control arms and anything else that needed it. Any ideas? I installed the 2 inch TC drop kit that came with it so I don't believe it would be the drive shaft but could be wrong. I'm waiting to get a Go Pro to mount and see if I can figure it out but any ideas would be helpful. I've seen similar posts but most seem to have the issue at higher speeds or only when turning. Also, there is no noise when I go in reverse, only in drive. Thanks in advance.
Old September 4th, 2017, 13:40
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Slow Speed front end noise
Are you hearing lug slap from the new tires ?
Still have a low pinion axle ? With a low pinion axle, and 4.5" of lift, an SYE is not optional.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old September 4th, 2017, 21:13
Thanks for the reply.
1. What is lug slap?
2. I'm not home from work yet to check but all signs point to it being low pinion being a 2000. That's a bummer.
Sent from my SM-G930V using Tapatalk
Front brake locks at slow speed....? Crow Horse OEM Tech Discussion 6 May 22nd, 2011 20:11
Front end noise after wheeling. metallic scrapping tapping with speed. sharq OEM Tech Discussion 8 June 7th, 2010 20:41
VERY slow speed consistent clunk (front) quaggy OEM Tech Discussion 5 May 5th, 2008 22:51
Info on a slow speed front end clunk. Angus Modified Tech Discussion 1 November 4th, 2007 18:33
whining noise from front end at speed. woodyjeep OEM Tech Discussion 5 June 3rd, 2005 08:39
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
