Old September 4th, 2017, 09:51
xCWolf's Avatar
xCWolf xCWolf is offline
Bring the Boom
Stiffen Leafsprings without more lift.
I just want to confirm something I'm curious about as I'm having trouble finding the answer on google.
I should be able to add a "helper leaf" to my spring pack and it will stiffen up the suspension under load (like if I have a bunch of stuff in the back it won't sag as much) and won't lift the truck anymore right? I'm happy with the amount of lift but it tends to sag If I fill up the back with a bunch of stuff.
Thanks!
Old September 4th, 2017, 10:11
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Stiffen Leafsprings without more lift.
Most of the helper springs I've seen are designed to work with stock springs, the arch won't be correct if you're running much lift. Other than that, yes...they add capacity without adding lift. Ive had pretty good luck with air shocks, but then you have to adjust air pressure if you load/unload/hitch a trailer, etc.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old September 4th, 2017, 10:16
ehall's Avatar
ehall ehall is offline
https://activesuspension.com/ there was a guy here who installed them, photobucket destroyed the write-up http://www.naxja.org/forum/showthread.php?t=1111656
my '91 beater rebuild
Old September 5th, 2017, 07:19
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
The addition of any leaf is going to give some lift but i would try an xj main leaf with the eyes cut off. Minimal lift and it will support the exisitng main better
Old September 5th, 2017, 07:27
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
If you're trying to stiffen it up without adding height, look for another leaf the approx length and arch of your main leaf, and add it to your pack.
What leaf pack are you running now?
Old September 7th, 2017, 12:18
xCWolf's Avatar
Bring the Boom
Rancho 1.5" lift leafs (they really give about 2.5" of lift) and 2" lift shackles.
Old September 7th, 2017, 12:20
cal's Avatar
cal cal is offline
Yeah I'd look for like an S10 pack and move just the main leaf over cut to the length of your main leaf. It would give you maybe .5" but add load capacity.
To stiffen or not to stiffen?!? jeepxj2007 Modified Tech Discussion 23 February 1st, 2011 20:13
What's going on with my leafsprings? Four2score Modified Tech Discussion 11 December 29th, 2010 12:52
WTB:Stock or 3" lift leafsprings jeff411sk8 SoCal For Sale 7 September 25th, 2009 11:42
Leafsprings Q Skaven OEM Tech Discussion 6 February 14th, 2009 14:22
WTB leafsprings... BackNBlackTJ Arizona For Sale/Wanted 0 August 27th, 2007 19:52
