Old November 28th, 2017, 19:41
Mikep_86441 Mikep_86441 is offline
Re: Going Through a Beater XJ 4.0. Rust Resolved !!
So happy to find out that this rusty bolt problem is not just with my XJ !!!
Here is what happened at the junkyard today !!
Edit: Uploaded corrected video.
https://youtu.be/zNinsI11H5w
Old November 29th, 2017, 22:34
Re: Going Through a Beater XJ 4.0. Vacuum Pump.
I've used this vacuum pump for the AC on the XJ and a Honda. Works great !!
So I did a review on it.
https://www.youtube.com/watch?v=9wjS...TmWu5MbvB7vGXX
Old November 30th, 2017, 18:13
Re: Going Through a Beater XJ 4.0. Got the oil pan out !!!
Can hardly believe the oil pan is out !!!!! Finally !!!!
Can't wait to see what's lurking in the bottom of the oil pan that caused the knocking !!!
https://youtu.be/9SvlBVjJf0A
Old December 6th, 2017, 06:32
Re: Going Through a Beater XJ 4.0. Head Bolt Cleaning With Vinegar.
It turns out that simple cheap white vinegar took the rust right off of the rusty head bolts. Amazing how well it worked. So I tossed in all of the rest of the oily head bolts. After several days, the remaining bolts are nice and clean, especially the threads. Then they were soaked in a water and baking soda solution to neutralize the vinegar. So today I blew them off with compressed air, then coated them asap with wd40. They will be ready come assembly day.
The junkyard head bolts I picked up a while back just went into the water rinse after soaking in the well used white vinegar. There were 1-2 inch diameter flakes of crusty black material floating on top of the vinegar. The vinegar did a great job on the 6 or so junkyard head bolts. So they will be grooved with an angle grinder for thread chasing after they go though the rest of the cleaning process.
Super clean threads allow the torque to go into tightening the bolts, rather than overcoming friction from dirty threads.
beater! ehall North Atlantic Chapter 614 December 3rd, 2017 07:32
Beater XJ itrack Modified Tech Discussion 7 April 1st, 2011 10:02
Who's got a Beater Rig? Letterman Sierra Chapter 10 November 6th, 2010 12:52
My new beater hollywood32 SoCal Chapter 11 March 9th, 2007 18:34
beater? skunkman Tow Rigs and Trailers 2 October 10th, 2003 08:26
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
