Old August 12th, 2017, 23:20
SofaKing's Avatar
SofaKing SofaKing is offline
Front axle not center. How do I center it? Help
Short story I bought a used 2000 XJ with 4 & half inch lift. After I got home I noticed the front sway bar links were bent like pretzels. I assumed it was from Wheeling. I bought a set of swaybar link disconnect style. While trying to install the new swaybar disconnects links. I found that the whole front axle is off-center. So the swaybar link disconnects are far apart on the driver side looking angled in. While the passenger side is super close and doesn't have enough clearance to disconnect and move up. Even the front coil springs are not in straight. My question is is there a way to center the front axle better in the XJ so things lined up correctly? I will try to post pictures later.
Old August 13th, 2017, 02:17
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
Re: Front axle not center. How do I center it? Help
you need to adjust the trackbar.
pics of your suspension and front end would help.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old August 13th, 2017, 05:32
lawagoneer lawagoneer is offline
Add an adjustable track bar to correct. It is possible to re-drill your axle end track bar mount but a good adjustable track bar does the best job to center the axle properly.
Old August 13th, 2017, 08:19
TRCM's Avatar
TRCM TRCM is offline
I would also not be so sure to assume the links are bent.....some model year factory links (like mine) are made with bends in them.
Old August 13th, 2017, 09:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Measurements and pictures would be very helpful.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old August 13th, 2017, 11:02
SofaKing's Avatar
Can I up load pictures off my phone?
Old August 13th, 2017, 14:58
89limited_hero's Avatar
89limited_hero 89limited_hero is offline
I use imgbb.com to upload pics from my phone. Or get a membership.
Old August 13th, 2017, 15:04
SofaKing's Avatar
Old August 13th, 2017, 15:13
SofaKing's Avatar
Went on imgbb.com opened an account. How do I attach/ upload to the post? Thanks
Old August 13th, 2017, 15:18
Kittrell's Avatar
Kittrell Kittrell is offline
I believe you can upload from your phone using the tapatalk app.
Old August 13th, 2017, 16:53
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
If you see or can get a link for your pics use/copy link between [img]. (add bracket befor the slash) /img]
Sent from my SM-N910T using Tapatalk
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old August 14th, 2017, 21:21
SofaKing's Avatar
https://image.ibb.co/cYZ1SF/IMG_0163.jpg
Old August 14th, 2017, 21:22
SofaKing's Avatar
https://image.ibb.co/jMuqMa/IMG_0164.jpg
Old August 14th, 2017, 21:34
Associate
you are lifted way too high for a stock trackbar.
buy yourself a quality double shear unit and get rid of that axle side drop bracket.
something like this one.
https://www.claytonoffroad.com/jeep_...84_2001_ xjzj
you should really also invest in a set of Control Arm Drop brackets or Longarms. youre lifted pretty high for short arms. and stock ones to boot.
Old August 14th, 2017, 22:35
SofaKing's Avatar
The guy I bought it from said it had 4.5" lift. Not ever owning an XJ in the past 18 years of driving. It's been a learning curve. It has aftermarket: coils springs, lower control arms, shocks, & ranch steering stabilizer up front. I believe add a leafs in the rear but not sure. And who ever put the lift in didn't put the longer shackles in the rear either.
I'm fixing a lot of things the previous owners did. So I'll add a new track bar to the list with the extended brake line and rear shackles.
Front axle off center A 1/2'' gsperaz Modified Tech Discussion 12 June 4th, 2010 19:59
Front axle off center even with trackbar unhooked viperbluelx Modified Tech Discussion 3 April 30th, 2010 21:04
Front axle center drop brake line ? Robb_In_AZ Modified Tech Discussion 15 July 3rd, 2009 01:14
My front axle is off-center? jeeperdavis Modified Tech Discussion 11 June 8th, 2006 16:59
Whats the best way to center your front axle? Dustinyork Modified Tech Discussion 5 February 15th, 2006 20:54
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
