Old August 7th, 2017, 19:53
1992xjJames 1992xjJames is offline
Newer gas tank in an older XJ
Anyone put a plastic tank out of a 98 and up XJ in an older XJ? Iv'e got a 1992 with 4.0 and the tank is by far the worst tank I have ever seen. I'm surprised its not leaking. Jeep had been sitting for the last 12 years with practically no gas in it. The gas turned to sludge and the top looks like it will spring a leak at any time. Thanks in advance for any info.
Old August 8th, 2017, 13:20
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Dunno. Suppose it is possible since the frame is essentially the same.
Not sure the fuel pump and regulator will work in a 92.
Wait here is a link on the same question http://www.jeepforum.com/forum/f11/9.../topics/862935
Edit
Another thread http://www.pirate4x4.com/forum/jeep-.../topics/615881
Seems the easiest is to put the metal tank back
Old August 8th, 2017, 16:25
old_man's Avatar
old_man old_man is offline
Re: Newer gas tank in an older XJ
You can get a brand new tank delivered from RockAuto for less than $100. In my book, it isn't worth the hassle.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old August 8th, 2017, 17:42
Thanks green Mesa xj. I was planning on using my new pump that I was going to install before I discovered the inside of my tank. I'll make it fit in the bracket. I thought about buying a new tank, but I would need a new sending unit assembly also. I can get a plastic tank with sending unit at my local upullit for 29.00. I'm on a budget right now or I'd just get everything new.
Old August 8th, 2017, 17:51
jabinco jabinco is offline
I just recently read on here that someone did it, I think it was Anak. He said it went right in. As you know, the pump and sending unit will be different. And you won't be able to get your pump out from the front anymore, it's on the top of the plastic tanks. Also, you might run into a problem with different fuel pressure.. something to look into.
Old August 8th, 2017, 18:08
That why I was going to use the pump only for the 92. The regulator is on the fuel rail.
Old August 8th, 2017, 18:12
I think the regular is built in the fuel pump or tank 97-01. But I really have no experience on the 97 up XJ
Old August 8th, 2017, 18:22
Dragonslayer Dragonslayer is offline
All of the above - plus, the later fuel pumps have no fuel return line as do the earlier cars.
As Green Mesa said, on later cars, the fuel pressure regulator is built into the pump
assembly and so you will have to do some creative fuel plumbing in order to get it
to work.
The resistive value(s) on the fuel gauge sender is probably different, too.
Old August 9th, 2017, 14:38
robert2008's Avatar
robert2008 robert2008 is offline
Sender is going to be different too, so if knowing how much fuel you have left is a priority it's definitely not worth the swap. As suggested, just buy a new tank of the proper vintage.
older 242 in newer XJ ? Rmart30 OEM Tech Discussion 5 June 21st, 2010 14:41
newer axles in older xj thicky OEM Tech Discussion 9 March 12th, 2010 08:04
newer gas tank in older xj iaml3lue OEM Tech Discussion 3 August 15th, 2008 20:27
Older or newer? SLAYER Non-Tech / Off Topic 12 February 20th, 2007 21:48
Will a factory gas tank skid from a 96 and older fit a 97 and newer? jeepguy97 Modified Tech Discussion 3 November 11th, 2004 16:38
