Old April 23rd, 2017, 19:47
kmanxj5050 kmanxj5050 is online now
0630 head into 01 XJ
I'm putting a motor out of a 98 into a 01 that I bought. I forgot about all the O2 sensors on the manifold in 01's. Has anyone done this? If so how did you work around it?
Old April 23rd, 2017, 22:21
biztyke biztyke is offline
Re: 0630 head into 01 XJ
you need an adapter plate. the 01 manifold does not line up properly with the older exhaust ports.
there might be a way to do it with an older manifold, but not sure about emissions and getting engine to run properly. the upstream sensors are important, even if emissions arent required as they determine air/fuel.
a member here made and sold an adapter a while back, looks like he still makes them: https://jeepexhaustadapter.com/
Old April 24th, 2017, 07:49
What about welding bungs for the up stream into the 98 manifold? They see everything pre cat anyways right?
Old April 24th, 2017, 10:27
md21722 md21722 is offline
The most proper solution is to use a 0331 head on top of the 98 block and keeping all the 2001 emissions/manifolds/cats in place. Tampering with emissions is against federal law and discussion of doing so is not tolerated on this forum.
Old April 24th, 2017, 10:51
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Aftermarket, performance headers, made for your 2001's emission exhaust, such as Banks. will cover the exhaust ports on a 930 head, without using any type of adaptor.
You will be able to retain the stock O2 sensors and two mini-catalytic converters.
You will have to fabricate brackets to hold the COP coil rail in place, since the 930 head lacks the threaded bosses that the coil rail bolts to.
http://www.naxja.org/forum/showthrea...highlight=0331
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old April 24th, 2017, 14:32
lazyxj's Avatar
NAXJA Member #1310
Whoops, should have said 630 head.
Old April 24th, 2017, 20:00
Right because the gooberment is watching naxja for someone rigging up O2 sensors on a 16 year old jeep.
Old April 25th, 2017, 16:24
go1lum go1lum is offline
Cali or fed emissions? If fed just use older style exhaust.
Old April 25th, 2017, 17:51
Its an 2001 they were all CA with pre-cats. Swapping the computer/eliminating the pre-cats to revert to 2000 with federal emissions is illegal.
Old April 25th, 2017, 17:52
The rules are the rules, if you don't like them leave.
Old April 26th, 2017, 09:58
So they totally did away with fed emissions in 01? My 00 is a federal emission jeep.
Old April 26th, 2017, 10:27
Heavyopp Heavyopp is online now
https://jeepexhaustadapter.com/0630-head/
I'm doing a swap now -- 98 grand engine with 27,000 miles on it into a 2000 XJ with cali emissions -- The 98 engine has a 7120 head
I bought the adapter plate above -- $120 shipped to your door -- It's well made and worth it to keep all the O2 sensors
You also need exhaust/intake gaskets for both the 0630 and 0331 heads
Old April 26th, 2017, 10:53
Correct. 2000 was available as federal or CA and 2001 was CA only.
Old April 28th, 2017, 07:01
Good to see everyone is so friendly around here.
Old May 3rd, 2017, 08:22
Can some one explain why the thin adaptor plate is needed? Why not just stack the gaskets on top of each other and bolt it up?
WTB 0630 4.0 head bldeagle10 Arizona For Sale/Wanted 0 October 9th, 2011 15:39
question switching from 0331 xj head to 0630 tj head jonnyz123 Modified Tech Discussion 2 May 15th, 2009 20:11
For Sale: 0630 Head wilsmick For Sale: Private Party Only. XJ ITEMS ONLY 2 May 10th, 2007 10:59
Need a 0630 head- jfs3674 Wanted: Private Party Only 0 November 3rd, 2006 14:24
