Old April 22nd, 2017, 12:29
1-tonxj 1-tonxj is offline
Steering shaft and trans speed sensor bolts
Got a 99 and lost a couple bolts in last many months of working on it ...Lost the transmission output speed sensor ratainer bolt after atlas install and I lost the steering shaft coupler bolt after the charlynn valve install . I think the steering shaft may be an m10 1.5x35 , but the trans output speed sensor...no clue.
Old April 22nd, 2017, 13:28
md21722 md21722 is offline
Re: Steering shaft and trans speed sensor bolts
Steering Shaft:
SCREW. Mounting. Hex Flange Head. M10x1.5x35.
Part Number: 06503210
Speed Sensor:
BOLT, SCREW. Fan To Fan Drive, Mounting. Hex Head. .312-18x.75, 5/16x18x3/4.
Part Number: 00220800
Old April 22nd, 2017, 16:29
Originally Posted by md21722 View Post
Steering Shaft:
Speed Sensor:
Awesome thanks !
Steering shaft/intermediate steering shaft, tips and write up xjtrailrider OEM Tech Discussion 4 January 1st, 2013 08:12
AX-15 5 speed trans. Mikegyver1 SoCal For Sale 0 November 1st, 2011 20:21
speed sensor????? livid xj OEM Tech Discussion 5 September 18th, 2010 18:04
Speed Sensor/Crankshaft Position sensor??? jacobyj2 OEM Tech Discussion 3 August 30th, 2006 16:12
speed sensor ?'s four_shot Modified Tech Discussion 2 December 1st, 2005 00:14
