Old April 14th, 2017, 20:18
01_XJ's Avatar
01_XJ 01_XJ is offline
Need a photo of fuel injector harness connection 97+
I saw the photo request sticky, but I think this post falls under having technical value. If not, please let me know and I can remove it.
If anyone would be able to post a pic similar to the ones below, it would be helpful. I have a 2001 XJ 4.0. I don't know if anything changed in the fuel injector wiring on the '00-01 when they went to the coil packs, but I'm guessing most of the 97+ should be similar.
I recently got my jeep back from having the engine rebuilt and have had a few issues with the quality of the engine reinstall. Today I was able to figure out what the burning plastic smell was that I noticed the past few days. Looks like the wires out of the rail that sits above the fuel injectors is routed down past the first runner on the exhaust manifold and has melted.
Here are a couple pics, with the first showing how it is routed (Blue circle), and a couple more showing the connector.
I've had this thing apart previously to change the 0331 head out, and to change injectors, and I could have sworn this part of the harness came around on the top and attached to where the green circle is on the first photo. Am I wrong? I know something is supposed to be there because there is the mount and one of the small plastic push rivet things sitting there.
It would be great to know how to route this. At this point, I think the connector is to melted to disconnect, so I'm probably going to have to cut it out and reconnect the wires.
Sorry if the pics show up huge, not sure how to change that from Imgur
Old April 14th, 2017, 20:57
Greenspan's Avatar
Greenspan Greenspan is offline
Re: Need a photo of fuel injector harness connection 97+
Looks like you were right, this is from my 98 XJ Sport 4.0, let me know if you need anything else. Man I need an engine clean!
http://imgur.com/a/0cjcg
Old April 15th, 2017, 09:44
Jeepedo129 Jeepedo129 is offline
The wires you have there are for your O2 senor. They usually route through the gape between the power steering pump and the intake manifold, however the way Greenspan has it works too.
Old April 16th, 2017, 07:22
md21722 md21722 is offline
Yes, those are O2 wires. On the 01 they Y out and are supposed to be secured by a bracket on the first bolt holding the fuel rail down (within the green circle in the picture).
Old May 8th, 2017, 12:20
01_XJ's Avatar
I guess I didn't save the post notifications and forgot to check back on this. The pic provided by Greenspan was exactly what I needed.
Jeepedo and md21722, correct that those are the o2 sensor wires, not sure why I wrote it differently in the first post. I knew there was a part of the harness attached to that bracket, but wasn't 100% sure it was the o2 sensor portion.
Thanks!
Fuel Injector Wiring Harness opie5150 OEM Tech Discussion 7 May 5th, 2008 15:57
YJ Fuel Injector harness clips OverlandZJ OEM Tech Discussion 1 August 14th, 2007 10:55
97+ 4.0L Fuel Injector Wiring Harness Wolf Wanted: Private Party Only 1 June 5th, 2007 17:56
Fuel injector harness poblems? Superhonky74 OEM Tech Discussion 7 September 29th, 2005 00:10
Fuel Injector Wire Harness Removal desertred OEM Tech Discussion 5 March 4th, 2004 20:06
