Old March 31st, 2017, 01:58
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
warn m8000 or VR-8
i thought i was sold on a m8000 so i wrote warn as to the differences between the m8 and the vr8 which seems to be better electronics....
3rd option smittybilt x20 10k
the new vr are contator based and are essentially identical to the m8000.
love merica, but m8 cable is 575$ add spydura 850$ good product
vr-8 500- 667$ no clue as to its reliability...
SBilt x20-549$ synthetic- the only reason its still in the race is because its stats out perform warn for heat dissipation and amp draw.
i would like to hear from anyone running these.
Old March 31st, 2017, 10:56
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Warn M8000 or VR-8
I have run a M8000, with synthetic line, for almost ten years without a problem.
The relay box is mounted under the hood, for protection from the elements.
That said, I have no idea which is the better winch and the M8000 is more expensive.
Few will have run both and even then, how do you actually compare them...pull speed, amperage draw, how much the winch heats up under a hard pull, quality of the mechanical build, there are a lot variables.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old March 31st, 2017, 13:17
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: warn m8000 or VR-8
The vr is 100% made and assembled in china. The m has a chinese motor but the rest is american made and assembled in the US
Warn m8000 Egodfrey NAC Classifieds 9 April 24th, 2014 09:10
Warn M8000 5spd_xj For Sale: Private Party Only. XJ ITEMS ONLY 2 October 16th, 2007 15:08
Warn M8000 mikeygone1 South East Chapter 0 June 10th, 2005 09:16
Warn M8000 OT For Sale: Private Party Only. XJ ITEMS ONLY 3 February 16th, 2004 07:00
