Old March 4th, 2017, 13:37
sls97xj sls97xj is offline
Alternate oil pressure port?
I want to run a mechanical oil pressure gauge, but not disable the stock gauge. Don't want a dead gauge in the cluster. With the wire and plug being pretty short and the oil filter being there, I would prefer not to put a T at the stock location. Is there another location that I can pick up oil pressure on a 97 4.0? Stock unit goes crazy on occasion, but verified pressure with mech gauge. That is the reason I want a mechanical.
Old March 4th, 2017, 13:47
Jeep Driver Jeep Driver is offline
Re: Alternate oil pressure port?
Not that I'm aware of.
Search for pics of a full mech cluster, easy to do with the '97 cluster arrangement.
Otherwise.......go to the JY or get an aftermarket oil filter adapter, drill and tap for 1/8npt on the pressure side............enjoy your new gauge.
Oil Pressure Port NOTNSUV OEM Tech Discussion 2 September 17th, 2012 20:51
Need A/C low pressure port for Renix pantera1973 SEC For Sale / Wanted Forum 1 June 27th, 2011 15:28
Transmission pressure port adapter? Talyn OEM Tech Discussion 0 March 7th, 2010 16:34
Where is the low pressure port? DannyXJ OEM Tech Discussion 2 October 13th, 2005 20:14
which is the A/Cow pressure port kubtastic OEM Tech Discussion 4 July 22nd, 2005 18:33
