Old March 3rd, 2017, 18:43
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
need another new radiator
40000 miles ago I replaced my rad with a new CSF 2-3 core, i forget. anyway this one has sprung a friggen leak! Its an easy job but this seems rather soon to need a new radiator and im kinda P.O. that ill have to spend that money on a rad again. what brands do you all recommend? any advice is appreciated.
Old March 3rd, 2017, 19:08
cherokeefan_1's Avatar
cherokeefan_1 cherokeefan_1 is offline
Re: need another new radiator
Take it to a rad shop and have them fix it.
Old March 3rd, 2017, 19:34
montanaman's Avatar
montanaman montanaman is offline
I had a csf 3-row for about 6 or 7 years. When it sprang a leak, I called csf and got a free replacement. The guy was very friendly and helpful. The only thing I had to do was send them pics of the sticker on the radiator, and the leak, and they mailed me a new one free of charge. I didn't even have to return the old one.
And the leak was my fault! I ran "Dex-Cool" antifreeze, which corroded the solder joining the tanks to the fins.
Here is the contact page for CSF: http://csfimports.com/contact-us/ Give them a call. I wouldn't be surprised if you get a free replacement also.
Anyway ... The replacement is still chugging along and cooling extremely well.
Old March 3rd, 2017, 21:18
i will absolutely get in touch with them. its a good build/fit radiator. im very surprised its leaking.
Old March 3rd, 2017, 21:24
i would but its my dd and kinda need to remove/ swap all in one take.
Old March 3rd, 2017, 21:30
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I have carquest replacement rad's in my XJ and MJ 3+ years no issues
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old March 4th, 2017, 08:51
There's always the dealer if they still offer a copper/brass style. My Jeep has the original one and no leaks, it's a 91 and always had proper maintenance from the start. Where did the leak start at? Solder joint or tube/fin? Seems most aftermarket stuff is not to the same quality like copper/brass thickness, quality of solder AND proper cleaning after solder. The solder flux is corrosive.
Old March 4th, 2017, 11:39
its leaking from the top right drivers side. its on the engine bay side and seems to be where the fins meet the tank.
Old March 4th, 2017, 12:08
Ian Christiansen's Avatar
Ian Christiansen Ian Christiansen is offline
I caused a leak in my CSF radiator and I took it to a local radiator shop and they had it fixed same day.
Old March 4th, 2017, 12:39
montanaman's Avatar
I would just Drive the leak until a free replacement arrives from CSF.
Old March 4th, 2017, 15:27
You could try to fix yourself. Clean and dry the inside and out. Grab a propane torch and some silver solder and flux. Flux it, heat, apply solder. They probably used some cheap solder and technique at the plant and a poor cleaning procedure afterward that left some caustic flux at the joint. Salted roads don't help either if the radiator wasn't correctly painted afterwards.
Old March 8th, 2017, 15:15
shanesaw shanesaw is offline
I had terrible cooling problems when I swapped in a CSF 2-row, so sent it back and ended up trying this all aluminum 3-row from Auto Dynasty on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have been running it for over 6 months now and so far it's been great. Cooling system hasn't gotten hot enough yet for my auxiliary cooling fan to kick on.
Old March 17th, 2017, 12:06
where is the sticker located i dont remember seeing one on install ?
Old March 17th, 2017, 13:22
Nm they want me to call whoever I purchased the radiator from and submit a warranty claim. No idea where I got it years ago. I had hope that would've worked thanks for the suggestion anyway.
Old March 17th, 2017, 16:59
Oh boy now I'm Pissued OFF. There's stop leak in my rad which means the shop that fixed my heater core must have dumped it in.
Can I test for radiator leak without removing radiator? jeeperguy21 OEM Tech Discussion 8 September 15th, 2010 13:06
Radiator Spout where hose connects to radiator overflow bottle.. gregmondro OEM Tech Discussion 10 August 16th, 2009 09:59
Radiator leaking... not a hose.. how big a job is it to replace radiator? tstaples OEM Tech Discussion 5 November 21st, 2007 10:34
New radiator leaking at cap - any fix short of radiator replacement? schmitty OEM Tech Discussion 8 June 25th, 2007 10:54
