Old January 29th, 2017, 12:44
AlexNL AlexNL is offline
15x8 3.75 stock 96 XJ tire size
Hi All,
Is there anyone out there who can tell me what size tire to run on a 96 stock XJ with 15x8" wheels with 3.75" backspacing.
I would like to not cut anything on the flares or fenders.
I will modify/add bumpstops if needed.
Pictures are greatly appreciated.
Thanks.
Old January 29th, 2017, 16:17
trippled trippled is offline
Re: 15x8 3.75 stock 96 XJ tire size
235/75-15 would be my choice
Old January 29th, 2017, 16:35
Jeep Driver Jeep Driver is offline
30 9.50 15, while you can still get them.
Old January 29th, 2017, 16:48
VAhasnoWAVES VAhasnoWAVES is offline
i prefer a 10.50-12.50 for an 8" wide wheel for bead retention.
Old January 30th, 2017, 01:14
Thanks for the input.
I don't think the width will be an inssue. I'm more worried about the diameter of the tire since the backspacing is 3.75". The wheel will be making a bigger radius when turning from full lock to full lock. It might end up hitting the flare coners (front and rear of the flare).
Anyone with actual experience with a setup like this?
I was looking at a 255/70R15 tire or a 235/75R15 tire. Just worried about rubbing on the flare/fender when turning.
Old January 30th, 2017, 06:32
dan1977p's Avatar
dan1977p dan1977p is offline
I recall only a tiny bit of rubbing on my 15x8x3.75 wheels when I had 33x12.50's on it at stock height. Lifted it 4.5" and the rub went away until I flexed it and then went away permanently when I trimmed the fenders.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old January 30th, 2017, 07:23
I had the opportunity to testfit a 15x8x3.75 with a 33x12.50 BFG KO. It absolutely destroys the flares when turning the steeringwheel only a quarter of a turn or so on my stock XJ.
Did yours come with the Upcounrty 1" lift package from the factory by any chance?
Mine is stock (no upcountry lift).
Edit: Here is the photo of the testfit (you can click on the image).
Old January 30th, 2017, 07:43
dan1977p's Avatar
I think you have your answer already. I may be off and didn't do the first test until after I had the lift coils up front. I know at one point, it barely rubbed in the rear of the flare. Must have been post lift since it's obvious you shouldn't run it like it is in the pic. You could take measurements and do some geometry to figure out the max tire size if you wanted to using those 33's as a reference.
SeXJ Build Thread
Old January 30th, 2017, 08:01
I tried mocking up the OD of various tire sizes. Biggest seems to be 235/75R15.
The rest hits the flares when turning according to my measurements.
I was just wondering if there are people who had the same 'challenge' with a stock height non cut 96 XJ before I purchase 500,- worth of tires that will or will not fit.
I think i'm pushing the envelope here with the stock height and crazy offset.
Might be time for a budget boost...
Old January 30th, 2017, 09:40
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
On the 2001 XJ, I run 33 X10.50-15 KOs, on 8 X 15 rims with 4" of offset, and they barely fit under the raised stock flares
You might be better served by buying wheels with more offset, maybe 4.5".
3.75" of offset is too little for most applications that keep the stock flares, especially considering the stock rims are 7 X 15 with 5.25" of offset.
The extra inch of rim width pushes the tire outward another 1/2", compared to to the stock 7" rims.
The outside rim of the 3.75" BS wheels are 2" further outward, compared to the stock wheel.
The flares on 96 and older models look larger than the 97+ models.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old January 31st, 2017, 01:54
Thanks for the reply.
I'm down to 2 options. Either getting a budget boost to accomodate for larger diameter tires. Or buy 235/75-15 so they don't rub on stock height.
I want to keep the 15x8 3.75 because i really like the agressive wide stance.
I'm probably gonna go with the budget boost first.
Old February 26th, 2017, 01:12
Update:
Yesterday i installed a RT Off-road budget boost (1.75") on my Xj. Now there should be a little bit more room to play with.
Any suggestions for 1.75" lift 15x8 3.75" BS tires?
Old February 26th, 2017, 20:18
Toostinky Toostinky is offline
I run 31x10.5 on a 15x7 wheel with a 2" spacer.
Do you wheel much with the sway bar disconnected? If so, the most important thing will be to bump stop properly to prevent rubbing. I added a 1.25" spacer to my bumpstops in the front, but also trimmed the fenders and relocated the stock flares up ~2". The rear I added 2.5" to the bumpstop and have zero rubbing with stock flares and no trimming.
Old July 11th, 2017, 04:10
Update:
Ended up with 235/75R15 (29x9.5x15) Cooper Discoverer AT3 Sport on the 15x8 3.75 BS wheels. 1.75 inch budget boost.
No rubbing at all.
I'm very happy with the result and the wide stance of the xj.
Old July 11th, 2017, 08:20
PacificEd's Avatar
PacificEd PacificEd is offline
Regular Joe
When I went to get ready to mount my new LT235/75R15 BFG AT KO2's on some 15x8 Ravine wheels, it didn't look like there was going to be any way to make the beads seat properly. Maybe my eyes were deceiving me because yours look good.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
max tire size stock xj seanjohn0226 Modified Tech Discussion 25 January 19th, 2013 19:20
Anyone with a stock size tire? bmyohn MWC For Sale/Wanted Forum 5 September 16th, 2010 20:43
4.56 gears at stock height stock tire size Muad'Dib Modified Tech Discussion 25 March 27th, 2008 17:40
Stock tire size k_kuch OEM Tech Discussion 11 July 4th, 2007 12:00
stock tire size?? frankenjeep OEM Tech Discussion 10 April 13th, 2005 19:06
