Old December 10th, 2016, 18:00
ljobbins ljobbins is offline
Front driveshaft question
I am swapping and building a lot of stuff on my xj and first on the list is building and 8.8 with gears to match my 33s. Next up is swapping the ax15 to get my Puegot out. while I have the transfer case out I was thinking of installing a sye. I was wondering if a front driveshaft can be used with no lift? I am installing a lift later when I finish collecting the parts so for a while it will have no lift to speak of. I can throw the transfer case back in without the sye and use the stock driveshaft but I thought if the front driveshaft would work I can avoid dropping the transfer case again.
I searched and I found people using the front driveshaft for lifts and custom shafts for no lift but I couldn't find much info for fully compressed length if I went over a speed bump or whatever with no lift would it be too small?
Thanks
Old December 10th, 2016, 18:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Front driveshaft question
If the driveshaft is centered in the slip yoke travel when installed, it should be OK. You will likely have to find a shorter driveshaft if there is no lift installed. You will need to test fit and/or measure to be sure. See the driveshaft length posting in the FAQ's to find a Junkyard driveshaft that will fit.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 10th, 2016, 18:31
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
You can't use an xj front shaft with an ax15, you need a longer shaft
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old December 10th, 2016, 20:13
themauler's Avatar
themauler themauler is offline
Find a V8 Grand Cherokee front drive shaft. The length varies by an inch or two for certain years but like mentioned before the OEM DS lengths are in the stickies. That will get you as close as you can without having a custom one made.
I ran an XJ auto front driveshaft with my ax15/231 with SYE for a little bit. Were the splines on the slip showing? Yes. Did it come apart? Never. At the time I was in a pinch. Later I took it to a driveshaft shop and they lengthened it so the slip is back in the middle.
Question about the front driveshaft Tony_SS OEM Tech Discussion 6 June 13th, 2014 12:25
Front driveshaft question chrisja77 Modified Tech Discussion 13 February 19th, 2009 13:11
front driveshaft question JERSEY99XJ Modified Tech Discussion 2 July 7th, 2006 22:47
Front Driveshaft question. vegeta Modified Tech Discussion 0 October 27th, 2005 17:43
Front driveshaft Question?? Christopher Modified Tech Discussion 9 September 5th, 2003 20:21
