Old December 9th, 2016, 14:54
kippo1 kippo1 is offline
Rough country rear cv drive shaft
Ok I searched and maybe using the wrong search words.
I have a rcouple rear cvs drive shaft in my cherokee. One of the u joints is bad. I know it's a 1310 series.
Napa, autozone, and advanced can not cross reference to get a part number. Does anyone have a part number for one of those places so I can give it to them?
Thanks in advance.
Old December 9th, 2016, 15:23
ehall's Avatar
ehall ehall is online now
Re: Rough country rear cv drive shaft
If its a 1310 joint you should use Spicer (or Neapco as second choice). Local chains don't usually carry those brands, but if you need one today you can usually find interchange by looking up the Dana / Spicer part number. Check here and look at the different 1310 u-joints available http://www.dennysdriveshaft.com/c120..._and_axle.html
I use greasables but I grease them every oil change. If you won't grease them often, get the sealed non-greasables and replace them every 1-2 years
my '91 beater rebuild
Old December 9th, 2016, 15:24
sinat01's Avatar
sinat01 sinat01 is offline
If I had to guess, id say its prolly the stock size u-joint. Id find out what size the stock u-joint is then get a spicer, you also can measure the caps if I remember correctly
Old December 9th, 2016, 16:09
dan1977p's Avatar
dan1977p dan1977p is offline
I've heard those are rebranded Toms shafts, btw. Also, the u joint spicer number is 5-153X. They should be able to cross reference them. OReilly's carries spicer now and that's where I've been getting mine. Only a couple bucks more expensive than rock auto.
Nice link, ehall. I just saw the 5-1310-1X which would be perfect here since I had issues with getting to the nipples on the 153's.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old December 9th, 2016, 16:24
Well they told me it was the u joints used in the front drive shaft. No one here carries spicer.
I got a moog for the bad one and I will order the spicers. After the kids fall asleep I'll change it out.
Thank you all for the info. I greatly appreciate it.
rough country SYE and drive shaft newheep SoCal For Sale 4 November 12th, 2012 08:09
Tom Woods Custom Drive Shafts NP CV style rear drive shaft... TRNDRVR For Sale: Private Party Only. XJ ITEMS ONLY 2 June 12th, 2011 14:31
Sagging Rear Rough Country 3" motroutmo Modified Tech Discussion 5 July 18th, 2006 10:46
rough country vs. RE rear leafs? lapaul Modified Tech Discussion 10 September 27th, 2004 22:18
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
