Old March 24th, 2016, 19:40
J33p98 J33p98 is offline
P0463,P1391
Hey Guys
I was wondering if anyone has run into this problem. I have a 1998 xj 4.0L
I have absolutely no driveabilty problems at all, however the MIL light stays on with the following 2 codes P0463,P1391, the light will go out usually when I get to a little less then a half a tank of gas and stay out for a few starts. This has been going on for about 4 years right after I had the engine rebuild. When the light goes out I can easily get through emission inspection. I just never know how long the lights will stay out so it's pain getting it through inspection. I did replace the KPS with an OEM one 4 yrs ago but that never solved the problem.
Any information would be greatly appreciated
Thanks
Old March 25th, 2016, 06:45
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: P0463,P1391
Follow the trouble codes and begin the diagnostics and inspection with those systems/components/wire circuits.
P0463 JEEP - Fuel Level Sensor 1 Circuit High
Possible causes
- Faulty fuel level sensor
- Fuel level sensor harness is open or shorted
- Fuel level sensor circuit poor electrical connection
P1391 - Intermittent Loss of CMP or CKP Signal. Loss of the Cam Position Sensor or Crank Position sensor signal has occurred.
P1391 – Possible symptoms:
(1) random misfire/stumble/stalling, often over bumps or right turns and when going into reverse.
(2) shorted out the Fuel pump/ECU power wire.
Possible causes
- Faulty Camshaft Position (CMP) Sensor
- Camshaft Position (CMP) Sensor harness is open or shorted
- Camshaft Position (CMP) Sensor circuit poor electrical connection.
Symptom:
P1391-INTERMITTENT LOSS OF CMP OR CKP
CMP SENSOR OUT OF SYNC
-DAMAGED TONE WHEEL/FLEX PLATE (CRANKSHAFT)
-DAMAGED TONE WHEEL/PULSE RING (CAMSHAFT)
-IRREGULAR LAB SCOPE PATTERN OF CMP SIGNAL
INTERMITTENT CKP SIGNAL LOSS WHEN WIRING IS WIGGLED
-IRREGULAR LAB SCOPE PATTERN OF CKP SIGNAL
-WIRING HARNESS INTERMITTENT
INTERMITTENT CMP SIGNAL LOSS WHEN WIRING IS WIGGLED
-SENSOR CONNECTOR/WIRING
-CAMSHAFT POSITION SENSOR
-CKP SENSOR CONNECTOR/WIRING
-CRANKSHAFT POSITION SENSOR
Potential Fixes:
Fix #1:
Inspect your wire harnesses for damaged wires, chafed insulation, or failed wire splices. Use a volts/ohms multi-meter to check the resistance of the ground wire circuits from each sensor. Replace corroded ground wires/connectors and clean ground wire connection points.
Fix #2:
Timing may off. Re-index the distributor/cam sensor per the FSM instructions, or replace faulty distributor/cam sensor pickup module.
Google Scan Tools, O-Scopes and Toothpicks, and read the article.
A mis-indexed distributor/cam sensor may exhibit surging, light bucking or intermittent engine misfiring. This will most likely occur when the vehicle is at operating temperature and under a light load at approximately 2,000 rpm. The proper indexing procedure must be used as outlined in the service manual.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old March 25th, 2016, 08:43
Re: P0463,P1391
Thanks for the list. I originally checked the connections with the ohm meter and everything seemed correct but I'm going to recheck it again. I have read about the re-indexing but I'm little foggy on the exact procedure.I'll google the key words you posted
Thanks
Old March 25th, 2016, 11:34
Tim_MN's Avatar
Re: P0463,P1391
I highly recommend you buy a genuine Jeep Service Manual. Test procedures and repair instructions are for everything in/on/under the Jeep are there. $ 7.95 at www.pacificcoastmanuals.com/
P1391: zluster OEM Tech Discussion 5 December 9th, 2010 06:32
P0463 - Fuel Gauge Reads Empty joalyons OEM Tech Discussion 4 August 17th, 2010 15:14
Intermittent no-start, P1391 billy120480 Modified Tech Discussion 2 November 8th, 2008 16:36
P1391, What the ? ahm OEM Tech Discussion 14 November 10th, 2007 07:38
Code Scan => P0463 Fuel Level Sensor A Circuit High Input joey99jb Modified Tech Discussion 0 July 26th, 2004 10:31
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
