NOVEMBER 2013 ROTM VOTING THREAD
vote!
  • kmanxj5050
    Votes: 11 20.8%
  • XJEEPER
    Votes: 25 47.2%
  • souske
    Votes: 5 9.4%
  • Bronzewyrm
    Votes: 2 3.8%
  • rocknxj
    Votes: 10 18.9%
  • Total voters
    53
  • Poll closed .
XJLI
Long Island, NY
DO IT!
kmanxj5050
1996, 4.0, AW4, NP231.
Front axle: D30 with superior alloy shafts, 4:88 gears, Lock right locker, Teraflex High steer knuckle, home brewed heim steering.
Rear axle: Ford 8.8, 4:88 gears, LSD, disc brakes
Suspension: RK 3 link in the front with 5.5" coils, 1.5" UBE's in the rear, 2" shackles, bravada bastard pack. 35x13.5x15 BFG Krawlers on Soft 8's
Bronzewyrm
2000 Freedom sport Aw4 np231.
front:D30 Hp non disco
custom 3link, pass upper, ballistic joints, on DOM
Ruffstuff panhard bar kit,
custom outside panhard bracket
JCR 1ton steering OTK
R.E. 4.5"coils
W.P. Diff guard
4.56 nitro gears
Yukon grizz locker
Yukon 4340 inner/outer shafts
Rear:29spl 8.25"
4.56 nitro gears
nitro cromo shafts
Ausi locker
custom u-bolt eliminators
Bastard pack
ZJ disks and e-brakes
custom shock relocation (axle side)
HD Shackle relocation brackets
Boomerang shackles 1.5"
Ruffstuff Diff cover
Others:
Rear skid
Custom crossmember
custom trans mount
custom t-case linkage
HD frame stiffeners
W.P. Rock sliders
W.P Front winch bumper
L.E.D. rock lights
Hella 550f's
Warn 8374 with 150' of steal, in cab controls.
Goodyear Wrangler Duratrac's 305/70/16
Factory 16" silver star wheels
JCR rear quarter guards (led tails)
PORC SYE
Ford E code 19lb injectors
1.5" wheel spacers
Trail cred
Character
Not installed and Waiting:
RADesigns rock and rail shifter
HD Roof sliders
Jeep tubes front fender armor.
Airaid cold air intake box "oiled"
maby more :roll:
Bronze.
XJEEPER
2000 Jeep Cherokee Sport
Under Hood
4.0L Motor
Fastman 62mm throttle body
Flowmaster Muffler w/hi-flow Cat
AEM Dryflow filter on custom intake tube
Genright hood vents
Optima Red Top battery
Viair 450 Air Compressor on custom mount
AW-4 Tranny with Shift Kit
231 T-Case w/32 spline shaft
Tom Wood’s Custom Driveshafts SYE
Woody’s Front/Rear HD Driveshafts
Drivetrain
HP D30 with ARB air locker-30 spline
30 spline Alloy USA axle shafts
Alloy USA tube seals
Rotated and gusseted housing inner C’s
T&T Customs weld-on Truss
Custom LCA Skids
Custom Upper and Lower shock mounts
Custom Trackbar w/JKS axle bracket
Custom trackbar truss/crossmember
Ruffstuff HD diff cover
WJ knuckle/brake swap with Akebono calipers
Custom 1.25” DOM steering linkage w/Tera TRE’s
Currie Anti-Rock sway bar with custom brackets
Prothane coil insert bumpstops
SS Long-travel brake lines
XJ D44 Rear with ARB air locker-33 spline
33 spline Alloy USA axle shafts
4:88 gearing
TJ Rear Disc brakes
Ruffstuff HD cover
Extended Bumpstops
Raised shock mounts
1.25” Billet Wheel Adapters
285/75/16 Maxxis Bighorn tires mounted on Jeep Moab wheels
Suspension and Chassis
T & T Customs Y-Link Arms and Crossmember
RE 5.5” Coils with .75 poly spacer
RE 1463 Leaf packs 3.5”
2” Custom anti-wrap spring perches
1” Custom boomerang shackle
Bilstein 5165 Front / 5150 Rear Shocks
Limit straps
T&T Customs weld-on Unibody Stiffeners
Temper Mental Racing reinforcement plates
JKS SBS plating-both sides
Armor
Custom Tube Front Bumper-1.5” DOM
Custom Rock Sliders 1.5” DOM
Custom 1.75" DOM Tube rear bumper -in progress
JCR Rear Qtr Guards-in progress
Miscellaneous
Bushwacker Flat Flares-painted to match body
Hella H4 headlights w/upgraded harness
Front Door storage pockets
Custom rear passenger seat headrests (ZJ)
Custom ARB plumbing with manual pneumatic switches
2 Gal Air storage tank
Uniden CB w/ Wilson 1000 roof mt. antenna
Fire ext , 1st Aid kit
Recovery straps , clevis, tire plugs, HiLift jack, LoLift Jack
rocknxj
1999 Cherokee Classic
4.0L I6 with Brown Dog motor mounts
AW4 tranny with 1st gear electronic lock
NP231 with Advance Adapters SYE
Optima red top battery with Ruff Stuff battery hold down
Magnaflow muffler
APN header
Rubicon Express 5.5" 6200 Extreme Duty SA lift
33x12.50x15 Goodyear Kevlar MT/R on 10" steel rims
RE monotube shocks in rear
Bilstein 5100 shocks in front
Currie steering with Goferit tie rod flip
RE swaybar discos and swaybar extension brackets
JKS Adjustable Coil Over Spacers
HD Offroad Engineering shackle relocation brackets
Sac Drivelines HD front driveshaft
Advance Adapters rear CV driveshaft
D30 front axle with Warn hub kit, chromo axles, inner axle sleeves, and Spartan locker
29-spline Chr 8.25 rear axle with PowerTrax no-slip locker
Yukon 4.56 gears
Ruff Stuff diff covers front and rear
Crown Performance stainless brake lines
Bushwhacker flat fender flares
JCR front Stage IV bumper
JCR rear Stage II bumper
JCR lower quarter panel guards
OrrFab Offroad upper quarter panel guards
JCR transfer case skid
Control arm mini skids
Con Ferr rack
XRC winch on Tomken removable plate
LeBaron hood louvers
Driving lights
Cobra CB and Firestick antenna
Moab stickers
More crap than I can remember...
souske
87/96 hybrid
CHP9" front, 5.13, grizzly, chromos, CTM Joints
trussed 8.8 rear, 5.13, ARB
241 OR transfer case
AX-15
bilstein 7100 front, 5100 rear
T&J offroad cage
Sliding ragtop
Sanden OBA, 30th Anv. Trasharoo, Full HDO stiffeners, Shackle relocators, leaf spring liners, TNT bellypan, Lebaron vents
50" LED lightbar, LED rock lights, LED interior lights, Leather ZJ seats, ammocan center console
Warn 8274
ZJ seats, raptorlined interior, custom AL storage panels
35" MTR-K's
Thanks for all the votes! Lots of solid, well built rigs this month. I really like Kelly's rocknxj rig.
