Old October 29th, 2013, 11:15
ctjkelley ctjkelley is offline
Anyone running passenger side drop axle?
Thoughts on running a passenger side drop front axle to accommodate a D300 or D20 TC. What is involved in the swap? Or is it easier to do a flip kit on the 300 and stay driver drop? Thanks for any info available!
Old October 29th, 2013, 11:55
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Anyone running passenger side drop axle?
I run a passenger drop axle, I used a Dana 300 behind the stOck 231 case using a crawl box setup on the 231. the floor is modified enough that I could no longer run a bucket seat in my Comanche, I needed to run the bench seat. Not sure how that would work out in a Cherokee. It was very tight clearance for the drive shaft to the oil pan, I cut the oil pan and relocated the pickup inside. I also have two notch out one little corner of the transmission bellhousing on my AW 4. I am running a very skinny drive shaft to allow it to fit, and it is still very tight I have very very limited of travel because of the drive shaft clearances.if you were running 5 inches or more of lift, I don't think you will have nearly the problems that I had.
88 MJ on 40's. 98 XJ on 35's. 01 XJ, 2wd, bone stock. 99 XJ, parts rig. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky 450, Kims 2011 R6, Kims. 99 Toyota Avalon, daily. 97 Miata, Kims.
And everything fits in the garage!
Kill yourself, or die trying!
Originally Posted by mako my day View Post
Johnx is #1
Old October 29th, 2013, 14:16
I'm running 4.5" of lift. Sounds my best option is to get the doubler and run a driver drop triple stick.
Old October 29th, 2013, 15:05
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
you also have portal boxes, which makes things a bit more difficult for you.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old October 29th, 2013, 16:50
JohnX's Avatar
Sarge <3 Ben
That's true. My pinion is similarly placed elevation wise as someone who has no lift. With 4.5" lift the OP should have it fairly easy for clearances....however the cutting of the floorboards will be similar.
Johnx is #1
Passenger side drop d44 in XJ? BruteNasty Modified Tech Discussion 4 January 29th, 2012 19:02
Going to a passenger side drop Red_daggsXJ Modified Tech Discussion 15 December 4th, 2009 11:47
running a passenger side drop front axle/t case 600dollarxj Modified Tech Discussion 1 April 29th, 2008 19:30
who all is running passenger side drop front axles performxj Modified Tech Discussion 0 July 25th, 2004 15:39
