I have a very bad feeling about this one. The person who was joking about parting out the XJ b/c of this might not be that far off base.
The hatch really has zero play or give. Moving it back and forth is not working. It's stuck hard. Also, I really don't think the outside liftgate door handle feels attached to anything. It doesn't feel like anything is releasing when I pull up. Do you think the inner mechanism might have gotten jammed or broken when the blanket got in the way of closing fully? I slammed the liftgate down hard, and it's got about 1/2" gap still. That means a lot of blanket stopped that heavy liftgate in its tracks. If that outside liftgate handle is doing nothing, maybe the liftgate is still hooked closed? If so, no amount of kicking or prybar will open this thing, right? Then what??
Also, I am having trouble removing the huge inside liftgate plastic panel. I was able to remove the 4 screws at the roof, and the 2 deep Torx screws in the liftgate grab handle at the bottom. But, I see a 2 screws about midway up on the extreme right and left side. These are impossible to unscrew with the hatch closed. Since they are in the middle, I don't think I can remove the inner plastic panel. I also don't really know how to pop off the bottom. Normally, you have room for a pry bar. Here, all you have is a crevice you can just stuck your fingers into. Can anyone give me some ideas on exactly what to do to remove the inside plastic?
All I can think of is to somehow cut away a small 3x3" area of plastic that directly covers the latch area. I need to buy a dremel anyway, or I can use a soldering gun as a makeshift saw. Once I expose the latch, maybe I can pick away at the cloth. I can then wait for a parted out 98 XJ and get another inside plastic panel. What an ugly solution, but at least it's a possibility.
Unbolt the lock catch from underneath. That should give you enough play
Thanks for this idea. I did look up from underneath the bumper, and did see 2 bolts near the latch. Are these the 2 bolts holding the bottom latch in place? Should I just fully unbolt them and release the liftgate open? Wouldn't this be an obvious security flaw when designing a car? If this works, the bottom latch will no longer hold the liftgate closed, and maybe it will be easier to pick out the cloth with it just dangling from the hook?
