Red jeep is up for sale
foxwar71
Foxboro, MA
Time to put my jeep up for sale since I bought a truck. I've owned this jeep for a few years, bought it to be a daily driver but sees a little trail riding time to time. It was bone stock with 120k on it when I got it. It was a non-New England jeep and was rust free and very clean. I've never had any major issues with it and I wouldn't hesistate to drive it anywhere. Its been on numberous 800-1000mile roadtrips to PA/NY and back without trouble. It has no problem pulling down mileage in the 20-22mpg range on those trips and on the highway. I have a folder full of recipts and such for all the parts I've put in it.
-1995 Jeep Cherokee 2dr 4x4 165,xxx miles
Base model jeep only options from the factory was 6cly and 4x4. A/C deleted with correct non-A/C climate controls.
Engine/Drivetrain
-4.0 I6
-AX15 5spd manual (changed over to Penzoil Syncomesh fluid)
-NP242 Fulltime t-case with SYE setup
-Throttle body spacer
-Magnaflow exhaust
-Rebuilt/sleeved driveshafts with Spicer joints
-All new cooling system (radiator/water pump/hoses/t-stat/etc) last winter
-Newer style aux fan with manual over rider switch
-New power steering pump and hoses last winter
-New belt, recent tune-up and filters
-A/C removed, only the compressor is left
-New starter last spring
-New TPS, IAC, & O2 sensors recently
Suspension/steering
-2.5" of lift
-ZJ or OME coil springs
-Teraflex adjustable LCA's with recent bushings
-RE superflex UCA's freshly rebuilt (just installed, under 300miles)
-JKS trackbar freshly rebuilt (just installed, under 300miles)
-Crown HD steering setup (just installed, under 300miles)
-Crown HD ball joints (just installed, under 300miles)
-Crown HD leaf springs with extra main leaf added
-Rusty's greaseable 3/4" shackle
-Front Edelbrock IAS shocks with lower spacers and stock replacement rear shocks
Axles
-Front D30 out of an auto XJ with 3.55 gears
-Brakes about a year old
-All new LCA and trackbar brackets built outta 3/16" plate (just installed, under 300miles)
-Reinforced UCA mount and new UCA bushings (just installed, under 300miles)
-Reinforced coil buckets and LCA skid plates (just installed, under 300miles)
-Reinforced diff cover
-297 shafts machined out for full circle clips and Spicer 760 ujoints
-Rear Ford 8.8 out of an Explorer with 3.55 gears
-Disk brakes, pads/rotors about 1.5 years old
-Homemade UBE leaf spring mounts
-Tubes welded to the center section
-Relocated shock mounts
-Crown bolt in e-brake cables
-Crown wheel spacers
Wheels/tires
-Special edtion dealer-only Jeep alloy wheels, one center cap missing
-31x10.5x15" Toyo A/T's with great tread left
Armor
-Homemade heavy duty bellypan with extra mounting bolts, t-case and tranny skid plate hoops
-ZJ gas skid trimmed to fit
-Reinforced front bumper with heavy duty mounts and steering box support plates, d-ring mounts
-Reinferced rear bumper with heavy duty mounts and framerail tie-ins, d-rings and hitch receiver
Interior
-Idiot lights swapped for full gauges with tach, correct miles maintained during swap
-97+ center console/ebrake handle swapped in, better cup holders
-Awesome pistol grip shifter made from a 97+ t-case shifter
Extrior
-Rear glass with heated defrost swapped in
-New windshield installed last summer
-Euro tail lights
-Body has some love marks courtesy of Rausch Creek
-Missing PS rear bumper end cap
Spare Parts
-Stock steering setups
-Misc stock front suspension
-D30 shafts with bearings
-Extra hatch shell
-Extra hood
-Stock tow hooks
-Other misc to go along with the jeep
Located in Foxboro, MA
Asking $2000 OBO
(Some pics show the black steel wheels, those were swapped out a few weeks ago. The first two pics are the most recent with the new wheels and new front suspension/steering upgrades.)
Somebody make me some offers on this, I dont wanna get to the point of parting this out just yet. I can also help with delievery within reasonable distance.
a buddy of mine wants to come by to see it this weekend. most likely going to buy it. ill PM u his number
my buddy got it, not making a complaint, idle is acting goofy, we were just gonna try re-setting the comp. any idea? other than that, the red jeep is awesome
thats probably all it is, I never reset it after putting in the new TPS and IAC.
