O-Gauge Steamer
- Colorado Springs, Colorado
From across the Country.
In particular, I need a Sea Level Reading and as many other poinst between there and the 6,000' altitude I am at. I need to see if the Factory MAP Sensor is a linear device.
So, to gather the data, turn the ignition on and with the engine not running, record the voltage at the MAP Sensor. The voltage can be taken by back probing the connector. There are three connection points on the MAP Need the readings from the center wire to ground.
At Sea Level, the voltage should be in the neighborhood of 4.6VDc. More or less.
So I will need the Altitude where the reading is made and the voltage reading. You should be able to Google the altitude for your City.
My plan is to use a (Spare, doesn't everyone have a spare Sensor?) Factory MAP and a Comparator Circuit to trigger a relay to shift my F/IC from "low" altitude to "high" altitude settings. Yes, I already know it is a complication so don't bother to tell me. I am retired, have tons of time on my hands and would like better resolution in the F/IC which, as of this moment, has a tune in it to go from Sea Level to 14,000'. I have all of the components, just need the readings to set the circuit trip point.
Thanks in advance.
Thanks in advance.
