Began weeks ago when hard starting. Finally got started, but seemed to run with less power. Got home, let it sit for few days. Wouldn't start. On odometer, said "no bus". Gauges didn't work, fuel pump not working. New battery, cps, still no start. Got under jeep, took apart fuel pump connector, plugged back in, tried to take apart camshaft pos sensor but didn't. Started right up. Hum! Dielectric grease fuel pump connector, tape up real good. Cleared bus code. Fixed? Ran fine for half day. On way back from fishing, gauges started dropping out and engine started bucking momentarily at times. Not consistantly. Managed to get home. Starts up fine, no obd2 codes. Bad sensor? Camshaft pos sensor? Alternator? Fuel pump?
Where to look? Checked dash connectors ok.
I appreciate any thoughts. Pulling my hair out trying to figure this out. I have a good code reader but nothing comes up.
Thanks.
Sent from my DROID2 using Tapatalk
Thanks.
