JeepNewb
- Goldendale WA
Anyone know any company and web site that get rid of this?!?
Cool thanks ya i was thinking about buying the solid axle shaft and ripping the other one out.. then making the plate and just bolting it right in.. would that work?!?
The only issue is because of the original two piece shaft there is no seal to keep the diff fluid from going down the tube to the CAD motor.
Agreed. I had a pretty steady leak out the passenger side axle tube, but just keep it topped off and you will be ok. I did take the precaution of pulling the cover and changing the oil anytime I did any wheeling that took me through deep water crossings. Better safe than sorry.
I'm looking at doing this but might just lock the collar over for the time being instead of changing the axle.
