BRIANHO13
<- Yum Chocolate
- Spring, TX
Here they are folks the original just got better still made from 1/4 steel and still made right here in AMERICA.
What you get is enough to do both sides, drivers side shown below. Includes bolt in bracket, anti crush bracket, shackle bracket, new shackle bolt, and grade 8 washers for the frame bolts (frame bolts not included as most of you already have some kind of nutstrip system in place reuse your bolts or get longer ones) I can not possibly predict what everyone currently has for nutstrips (bolt type size etc) I can not supply the hardware with this kit that will meet everyone's needs.
First remove the original shackle and shackle bolt.
Next insert the anti crush bracket into the bolt in bracket.
Insert this assembly into the original shackle box and reuse oem bolt, and bolt to frame.
Next bolt up shackle bracket and install shackle into desired location.
Repeat on other side and thats it.
You no longer have to mount these flush to the frame as the mounting slot for the original shackle bolt allows for the bracket to be located up to 1/2" inch off the "frame", taking into account hitches and/or skid plates.
The rear corner of the bracket will be removed for 98 and newer models.
These should be on the website and available to purchase no later than 7/10 of 2011.
Sorry I didn't do some silly install video.
