Old January 31st, 2011, 14:16
Distended's Avatar
Distended Distended is offline
Cherokee Clutch Pedal Assembly Discontinued...Now What?
So options are cook up your ownor pick n pull? Is there an aftermarket clutch pedal assembly?
Does anyone know if they clutch pedal assemblies differ from year to year? Hope I am not only one in this boat...
Old January 31st, 2011, 15:02
Distended's Avatar
Re: Cherokee Clutch Pedal Assembly Discontinued...Now What?
Bueller?
Old January 31st, 2011, 15:27
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
I'm gonna clue you in here..... wait longer than an hour before bumping your thread.
Secondly, you give zero details about your rig, or what you're up to.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old January 31st, 2011, 17:05
Distended's Avatar
Clutch pedal assembly is broken. Pedal swings free. Chrysler parts guy and local shop where 1996 Cherokee is waiting for repair both say that that assembly is no longer available. So I am looking for any options I may have for repair. Wanted to know if an after market manufacturer exists.
Old January 31st, 2011, 17:10
x99j's Avatar
x99j x99j is offline
what about a wrangler clutch pedal? maybe 4 wheel drive hardwares catalog, or quadratech?
Old January 31st, 2011, 17:40
Distended's Avatar
Will scope it out. Hopefully the entire assembly is interchangeable as pedal is ok but the connection between it and clutch assembly is broken.
Did a search and found a few similar threads but diid not see a solution.
Thanks.
Old January 31st, 2011, 18:02
ChiXJeff's Avatar
Curmudgeon
Okay, that's more like it.
Has anyone actually located the break? You might have to stand on your head to see it, but if the pedal arm assembly has a break, you should be able to spot it. The master cylinder comes through the firewall above the fuseblock. Note, be care when tinkering in this area, the fluid will slowly dissolve the fuseblock.
ChiXJeff
Lifetime member
Old January 31st, 2011, 18:34
Distended's Avatar
Shop located the break & said there appears to be some sort of ball joint that has deteriorated. Happened late in afternoon yesterday at intersection and I had to get it towed to shop. Since it was dusk I did not get good look at it.
I may just get it towed back home and head to Pick n Pull.
Old January 31st, 2011, 18:43
ChiXJeff's Avatar
Curmudgeon
Unless I'm wildly hallucinating, that ball joint is on the end of the master cylinder piston. I don't remember if it's threaded on, or more permanently attached. If it's threaded, then a p-n-p would be good, assuming they've got a stick shift XJ on the lot.
If it is threaded on, I'd take the joint off and see if I couldn't match it up at the local auto parts store.
ChiXJeff
Lifetime member
Old January 31st, 2011, 19:13
Cascade Carl Cascade Carl is offline
It must be the metal stud where the push rod attaches.
Old February 1st, 2011, 07:22
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Here's the thing we're talking about.
If it's the plastic end on the push rod, I think it's threaded on, or otherwise removable, and could either be replaced or fabricated. The pedal assembly itself changed in 1997, I think, and no longer has the same arm on the side, but the push rod might be the same. I can't confirm that, and I'm not going out in today's snowstorm to check.
If the pedal assembly itself is broken or bent, it should be possible to weld or otherwise repair. Make sure that the side arm of the pedal is not bent. The weld at the top has been known to fail, allowing the side arm to bend outward or twist, and this will destroy the push rod end, as well as causing premature master cylinder failure. The one pictured (in my 95) is unbent.
My son's 96 had this problem. Fortunately his brother welds, so he fixed the pedal assembly. He also was able to fabricate a new end for the pushrod, so we never had to find out what was available for replacements.
Old February 1st, 2011, 11:46
Distended's Avatar
Thanks for the pic and the background info.
I think I am going to get the Cherokee towed back home from AAA shop & see if I can fab something myself. Chrysler dealership is looking into how they would address this but I think they might be in same boat as the AAA shop, i.e. either wait for a Cherokee to show up at Pick n Pull or fab a gizmo themselves.
Thanks again!
Old February 3rd, 2011, 05:04
Distended's Avatar
Turns out the weld that connects the lever to the clutch push rod...broke. Shop welded it up and I placed it back in and we are back on the road. Gonna keep my eyes peeled for a "back up" clutch pedal at Pick n Pulls. Also I noticed from the service records kept by prior owner that this apparently happened earlier in this Cherokee's life.
Thanks for your help.
Old February 3rd, 2011, 07:47
NAXJA Member #760
Yup, that's the weld that failed on my son's 96 too. Son #2 rewelded, and it's been fine. I wonder if there was a bad batch of these in 96.
Old February 4th, 2011, 03:43
KD3NE_ KD3NE_ is offline
Considering I just bought a 96 XJ with a 5 speed, this thread is great.
Next time I go to Pick N Pull I may yank one of these out and keep it on the shelf.
Thanks for posting,
clutch/brake pedal assembly 61scout80 For Sale: Private Party Only. XJ ITEMS ONLY 1 December 4th, 2009 09:42
87-93 Clutch Pedal Assembly Goat Wanted: Private Party Only 5 October 14th, 2008 03:36
92 clutch discontinued, what to do? xcm OEM Tech Discussion 6 September 2nd, 2008 06:05
Grand Cherokee (ZJ) BRAND NEW A/C Clutch Assembly, $75 shipped selarep For Sale: Private Party Only. XJ ITEMS ONLY 0 May 9th, 2007 03:27
XJ Clutch Pedal and Sled Assembly KillerZJ Tow Rigs and Trailers 4 June 3rd, 2004 07:50
