Old December 31st, 2010, 13:37
mudrat mudrat is offline
excessive brake dust on one wheel?
hello, i have excessive brake dust on the drivers front wheel. it looks like dust from a metallic pad. i bought the jeep a few months back with a bent rear axle shaft and changed out the rear brakes with ceramic and of course got a new shaft and seals. could it be that the previous owner had changed out only one wheel with metallics.the rig is not pulling or shaking or smelling like burnt pad and the rotors pads and pistons all seem to be good. i am just seeing if ai am missing something here.... thanks 94 XJ 4.0 3" lift with 31 DC's
Old December 31st, 2010, 13:46
old_man's Avatar
old_man old_man is offline
Re: excessive brake dust on one wheel?
Make sure that the caliper slides freely on its mounting bolts.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old December 31st, 2010, 14:07
heyhar's Avatar
heyhar heyhar is offline
And that the brake pads are not dug into their mounting surfaces. Had to fix them on my '96, as the pads were dug into grooves, and the outers were not releasing properly, always dragging.
Old December 31st, 2010, 15:17
hey har... what do you mean by dug in?
Old January 2nd, 2011, 17:49
Durango-Bob Durango-Bob is offline
The contact point between the pad and the knuckle gets a divot worn into it and can cause the pad to hang up.
Old January 3rd, 2011, 12:39
joe_peters joe_peters is offline
Read this, even has pictures: http://www.jeepforum.com/forum/f9/xj...rooves-924713/
Old January 3rd, 2011, 17:21
x99j's Avatar
x99j x99j is offline
i bought a chevrolet c-1500 not to long ago. i went to inspect the front brakes and each side had different pads in it? you could be right and this be your problem?
Excessive brake pedal travel Chrisc321 OEM Tech Discussion 7 January 3rd, 2010 21:06
brake dust shield jeepnleo OEM Tech Discussion 4 July 17th, 2009 18:52
Front disc brake dust shields? bdiamond Modified Tech Discussion 5 June 7th, 2009 23:00
zj disc brake dust sheilds other options scottanchee Modified Tech Discussion 0 March 9th, 2007 16:52
Disk brake dust shields- need them? JKTXJ Modified Tech Discussion 3 May 15th, 2006 07:04
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
