Old December 2nd, 2010, 13:56
okc4x4 okc4x4 is offline
Electric Door Lock\Windows - Did the "window lockout bypass" mod
Hey all,
Before I get flamed, please let me explain. First off I have a new 99 Jeep 4dr Cherokee Sport and I did do the window lockout bypass mod.
I am able to roll the windows down from the Drivers Side and not the other 3drs. I searched and did the "window lockout bypass" paper clip mod and presto, the windows work correctly for each door.
I have also tried a new switch and it fixed the windows.
The door locks do not work from the driver or the passenger side. I am thinking that the wiring may be bad. I checked the fuse under the pass kick panel and it appears to be good.
Guessing I need to look at the wiring now? According to the manual, it looks like the yellow wire is the door lock wire, can anyone confirm this?
Thank you in advance,
Old December 2nd, 2010, 15:04
Original_MudButt's Avatar
Original_MudButt Original_MudButt is offline
Re: Electric Door Lock\Windows - Did the "window lockout bypass" mod
Sorry, I don't have personal experience with this.... But it sounds like you are on the right track. It probably is a broken wire. Broken wires are common where they go thru the rubber boot between the body and door. Good liuck.
wanted: 1991 xj driver side door window and door lock switch panel XJSnowMan23 NAC Classifieds 0 March 21st, 2010 16:25
"97 XJ-electric window replacement Indian Joe OEM Tech Discussion 0 January 24th, 2010 14:58
week door lock and slow windows??? benulis55 OEM Tech Discussion 5 July 22nd, 2009 12:14
2 door rear electric windows unden42 OEM Tech Discussion 6 December 7th, 2007 20:21
Replacing the exterior door window trim "squeegee" thing. montanaman OEM Tech Discussion 14 March 4th, 2006 18:17
