'89 xj
dana 35 non-c-clip rear end
pinion shaft uses roll pin for retaining, not bolt
the pinion shaft that came with my lock right has a retaining pin hole in it that is smaller than my stock one. i dont think the roll pin will fit in it.
the manual for the lock right says I should re-use my pinion shaft anyways. is this true?
my stock pinion shaft has notches cut in it (no they are not WORN, they are clearly cut into the shaft), while the lock right shaft does not. what is the relevance of that?
i bought my lock right kit used, so maybe the guy just threw his pinion shaft into the kit and i should ignore it?
