98NWCherokee
- Portland, OR
I'll keep this short since the AC posts lately have been plentiful. I have the partial AC operation so many folks have on their 97+ XJs. Mine is a 98 and the system works fine for awhile and then cuts out with no pattern I can decipher. I know when it cuts out that the compressor clutch is not cycling.
Here's the thread I found that matches what I have going on
http://www.naxja.org/forum/showthread.php?t=1034576&highlight=air+conditioning
My question is in regards to something xj_mike did. I believe my problem results from the compressor clutch not engaging or failing to engage after the engine gets hot. How do I adjust the gap here or remove the shim in the clutch pack that is referenced in this thread? When my AC clutch engages, the system works beautifully and puts out freezing cold air. Am I barking up the wrong tree here? I'm tired of wondering whether I'll have a sweaty drive home or not.
I don't get a big puddle after parking(evaporator freeze-up) and its not the low pressure switch. The sytem also seems to hold a charge as it's still working sporadically since the recharge last summer.
Examples of strange operation:
yesterday AC worked for 12 minutes before clutch stopped engaging at 75 degrees
Day before yesterday AC worked for 60+ minutes in 95+ degree heat.
(gotta love the overhead console with temp gauge)
Thank you.
Thank you.
